Old 08-20-2007, 02:19 PM   #1 (permalink)
Passanger side window not working!
I found out last week that the passenger side window is not working anymore. When I push down on the roll up/down button, I hear a buzzing sound but the window does not move.
I did some research and found several people had the same problem and it was either the regulator or the motor.
Did anyone have the same symptoms? (Buzzing noise?) And do you guys think I should take off the door panel myself and poke around?
Thanks
shazam786 is offline   Reply With Quote
Old 08-20-2007, 02:24 PM   #2 (permalink)
Speedratchet's Avatar
Re: Passanger side window not working!
Same problem here and I replaced the motor and regulator.
Visit me at: Speedratchet
Old 08-25-2007, 07:46 PM   #3 (permalink)
Update: I end up taking it to a Chevy delership. They replaced the motor/regulator. It works fine now. I had an extended warranty so I only had to pay $100. The total was $500 plus!
Old 09-21-2007, 08:20 AM   #4 (permalink)
C-5 window regulators are notorious for failing and I've also had both replaced recently under my GMPP extended warranty. You are right about the $500 price--my dealer said they charge ~$450 for the repair.
Melsy
'03 Red/Mod Red
Melsy is offline   Reply With Quote
Old 09-21-2007, 07:19 PM   #5 (permalink)
Cool. Thanks for the update.
passanger window stuck up... bluethunder C5 Z06 - Grandstand 17 11-09-2007 07:25 AM
Help! Window/Lock Not Working! =( Termin8r27 C5 Z06 - Tuning & Electronics 7 07-12-2006 09:15 AM
DS window not working, module or window switch? eviLS6 C5 Z06 - Pit Road 4 07-09-2006 11:34 AM
Anyone experience sand caught in the side window felt scratching the window? piker C5 Z06 - Grandstand 11 03-04-2006 11:07 PM
Passenger side Heat not working. ZO6supra C5 Z06 - Pit Road 4 01-31-2005 07:30 AM
