Old 07-22-2008, 08:47 PM   #1 (permalink)
Squeaking on accelaration
Hello all!
I have a question for anyone that might have an idea to what could be causing my problem. My 03 c5z is making a sqeaking noise for a split second when I start to accel, then stops as my rpms continue to climb. Usually happens around 2000 rpm. Almost sounds like a belt slips for a second or can the alternator make a noise like that? Any ideas???
Thanks
JK4Z06 is offline   Reply With Quote
Old 07-23-2008, 06:53 AM   #2 (permalink)
DennyM's Avatar
Re: Squeaking on accelaration
Could be the alternator, but for starters ... try some belt dressing and see if it stops.
'nother possibility is a weakened idler tension pulley ...
Since some have experienced throwing a belt on high rpm downshifts, the preferred OEM replacement is the LS2 tensioner, which has higher pulley sides ...
Old 07-23-2008, 08:37 PM   #3 (permalink)
It is probably one of the tensioners. I had mine start going at 14,000 mls and it did squeak some times but I overlooked it. Then my belt let go and hit my hood, just ripped the liner. Dealer told me it was common and my old Z was an 03 also.
Old 07-23-2008, 09:00 PM   #4 (permalink)
Check your belt tensioner.
ZO6 AL-X is online now   Reply With Quote
Gas pedal squeaking bjaber The Garage 4 09-05-2006 09:48 AM
Exhaust squeaking olf dog C5 Z06 - Grandstand 3 07-27-2006 01:16 PM
MY NEW z06 brakes squeaking Dr.Bigg C5 Z06 - Pit Road 7 01-07-2005 02:55 PM
Squeaking Durastops John Weitz C5 Z06 - Pit Road 2 09-23-2003 09:40 PM
Squeaking brake? Rapid Transit C5 Z06 - Pit Road 3 03-31-2003 09:40 PM
