Could be the alternator, but for starters ... try some belt dressing and see if it stops.
'nother possibility is a weakened idler tension pulley ...
Since some have experienced throwing a belt on high rpm downshifts, the preferred OEM replacement is the LS2 tensioner, which has higher pulley sides ...
