Old 12-16-2007, 07:53 PM   #1 (permalink)
Surging with a big cam, solutions?
I have an 02 ZO6 with LG pro headers and a 232/236 duration cam that I have tuned and it runs well and has good drivability except for one problem. It will surge and try to die right after starting it when already warmed up. Cold start is no problem. And it only does this for about the first 20 sec. after a warm start then it is fine. I have already SD tuned it and re-enabled the MAF. The LTFT's are very good at +/-4. It idles at 25 deg advance. Any suggestion from the experiened tuners. I can e-mail a .hpt file and a log that demonstrates the problem to anyone willing to take a look.
ZO6 Bryan is offline   Reply With Quote
Old 12-18-2007, 07:25 AM   #2 (permalink)
Re: Surging with a big cam, solutions?
Bump
Can anyone help with this. What's going on in the first 20-30 sec after start-up? I've already lowered the afterstart enrichment and tried several other things. Done the VE tuning already. Is it something to do with the idle air routine coming online takes that amount of time or is it something to do with fueling. Like it takes 1/2 a minute to switch to MAF from SD right after start-up?
Old 12-18-2007, 10:24 AM   #3 (permalink)
Super Moderator
FRC Tom's Avatar
Send me your file and I will do my best to fix the problem.
ttt@c5frc.com
232/236 is what I have been running for years, first with a s/c and now with TTs.
It is what it is
Old 12-18-2007, 01:41 PM   #4 (permalink)
thats awesome Tom..
What a great offer.
Let us know how it works out.
Happy holidays.
JB
Old 12-18-2007, 02:02 PM   #5 (permalink)
ttt@c5frc.com
Thanks for the help. I'll send it tonight from my laptop when I get home
Old 12-24-2007, 09:13 AM   #6 (permalink)
Eddie 70's Avatar
Just curious as to how this has turned out. My sons camaro does this and it has a relatively small cam. We are still playing with the tune.
02 EB Z06 No Mods Yet
12125 miles on 11/10/07
32619 Miles as of 11/09/08
Old 12-24-2007, 10:14 AM   #7 (permalink)
FRC Tom has my file and I'm waiting to hear back from him. With the holidays I figure he has more important things right now. Didn't want to rush him.
Old 01-07-2008, 07:05 PM   #8 (permalink)
I have to give thanks to FRC Tom for his help. After some changes he made to my HPT file and a little tweaking I did after that, the car runs great with no surging and great drivability for a cam of that size.
Old 01-08-2008, 08:11 AM   #9 (permalink)
Super Moderator
FRC Tom's Avatar
Very welcome Bryan.
Yes I was tied up and i do poligize for not getn the file back to you sooner.
Any other probs jus let me know.............................
I try not 2 turn wrenches ne more, I am a PC tuner...
merry, merry and a happy.
Old 01-27-2008, 01:03 PM   #10 (permalink)
RC45's Avatar
So what was the cause and then the solution?
It is interesting to read about these issues - but it would be even more interesting to hear the technical discusison surrounding the solutions
Old 01-28-2008, 12:41 PM   #11 (permalink)
Super Moderator
FRC Tom's Avatar
There are a number of idle airflow tables I work with.
Base airflow and Throttle Follower in nuetral and gear.
Depending on the problem I either increase or decrease the numbers.
The follower tables dictate how fast the throttle closes when you get off the pedal.
There is also seperate spark advanced tables for idle that I change.
Then the VE table from 1200 rpms on down I will normally decrease by 10-15%.
Old 01-30-2008, 02:28 PM   #12 (permalink)
RC45's Avatar
Thanks - very informative.
Problem solutions and alternator warning spdrcrj C5 Z06 - Pit Road 0 06-14-2005 09:23 PM
Header Heat Solutions ST1100 The Garage 2 05-02-2005 10:12 PM
Ported oil pump = higher pressure = dipstick pops out - solutions? Redshift C5 Z06 - Pit Road 10 12-03-2004 10:13 AM
FS: C5 Solutions Column Lock Bypass Module Social_Engineer Member Sales - Parts & Cars 4 06-26-2003 12:19 PM
Hurst/mgw Shifter Noise Solutions?? Z06ROD C5 Z06 - Pit Road 21 04-30-2002 08:03 PM
