Old 08-31-2007, 07:21 PM   #1 (permalink)
Traction control system
Hello fellow mustang slayers... I've been getting a "check engine" light for my traction control system. I've replaced the traction control module and cleared the code via a friend who is a chevy tech. He brought the hand held computer over and reset my computer. We also replaced the module with a brand new one. I took the car out and I was racing on the "track" at about 120 I droped into 4th and put it to the floor and I got the check engine warning and the car went into "safe mode" ie.. it won't go over 60 mph. So then my buddy came back out and he said a couple screws appeared to have losened up and he tightened them. Low and behold , it did it again. I pulled out of a gas station and tached it out and right when I got to 3rd it went back into safe mode 60 mph max speed. I was wondering if anyone else is or has had this problem. I want to keep this car, but if I can't drive it the way it was designed to be driven then there is no point in keeping it. Has anyone had this problem or is there a way to override the traction control system? I can handle the car, I mean I like having the traction control system to help save me from myself if I needed it, but I could live without it knowing that I could easily swap ends if I wasn't careful with the throttle. I just wish I had it tonight,, I always end up wasting some 350 z's on the way home from work on Friday nights. Thank to all for any insight.
210MT is offline   Reply With Quote
Old 08-31-2007, 09:06 PM   #2 (permalink)
MikesZ06's Avatar
Re: Traction control system
Not really sure what the problem is but getting rid of the car seems a little drastic.
I'd take it into a dealership where they can do a proper job of analyzing the computer to find out what's wrong.
That's just me....
9.87 at 141mph
& 2007 Black C6 Z06
Old 09-01-2007, 10:05 AM   #3 (permalink)
There is a way to turn off AH/TC via the button on the center console, but not sure if that will fix your problem. To turn the system off press the TC button. You should see a message on the DIC saying the system is off. If you press and hold the button for about five seconds, the system will go into Competition Mode (or Comp mode) which turns off TC but leaves AH on, however with more aggressive intervention points.
AH/TC faults are fairly common. By my read of similar posts, many problems seem to occur on wheel speed sensors (part of the ABS and AH/TC systems).
You can call up the fault codes on the DIC, or by using the GM tech hand held computer. The fault code would give you a better idea of what portion of the system has failed and what to do to fix it. The service manual has corrective action procedures listed for every fault code the system has. Pretty handy reference.
Good luck sorting your problem out.
Old 09-11-2007, 09:08 AM   #4 (permalink)
[quote=Subdriver;1191446] If you press and hold the button for about five seconds, the system will go into Competition Mode (or Comp mode) which turns off TC but leaves AH on, however with more aggressive intervention points.
dgoetz is offline   Reply With Quote
Old 09-11-2007, 09:14 AM   #5 (permalink)
I am new to Corvettes and just purchased a 04 ZO6 for autocross with no owners manuel (which I have ordered). I have been just turning off the TC button. What is AH? and is the competition mode what I should be using for Autocross?
Old 09-11-2007, 10:08 AM   #6 (permalink)
DennyM's Avatar
IIRC, you're a pretty serious AutoXer ...
For the C5 Z06 Standard default "all on" is ASR on and Active Handling on.
ASR reduces throttle in wheel-spin conditions
AH applies brake at appropriate corner to correct a high-yaw condition (orientation of car vs orientation of wheels).
Pushing button and releasing disables ASR and AH (all off). Pushing button and holding ~ 5 seconds brings up "Competition Mode" in which ASR is disabled but AH remains enabled.
I would think, for AutoX, you would want "all off" if you want to throw the rear around on purpose. YMMV ...
Old 09-13-2007, 06:06 AM   #7 (permalink)
IVOZ06's Avatar
Send a message via Yahoo to IVOZ06
I guess the main question is...What codes are coming up?
Knowing the codes, we can stear you to the correct answer.
I do not suffer from insanity, I enjoy every minute of it!
CLICK FOR MY PICS
LIFE IS TOO SHORT, HAVE FUN, NO REGRETS
IVOZ06 is offline   Reply With Quote
Traction control beerkat C5 Z06 - Pit Road 11 12-12-2006 11:19 AM
Traction Control LethalZ C5 Z06 - Pit Road 13 06-07-2006 06:33 PM
FS: Brand new RaceLogic traction control system with launch control jimlab Member Sales - Parts & Cars 14 12-31-2005 03:51 PM
Traction Control rebells6 C5 Z06 - Pit Road 13 08-11-2005 12:48 PM
Traction Control Mike B C5 Z06 - Pit Road 6 11-02-2002 08:50 PM
