Originally Posted by itsaz
If it ain't broke.......
You might want to do some data logging to see what your fuel trims are doing, if you are experiencing knock retard and that type of thing. Anybody with an HPTuners setup can do this without requiring credits or charges to their account.
Sounds like the car's just fine. Maybe a bottle of Techron and you're good to go.
Tim..Costco has Chevron injector Cleaner with Techron by the 6 pack for about 12 clams (I think)
Techron should be part of the fall ritual....
- run gas tank low...1/8 or less...put in a bottle of techron
- drive around for as long as you dare...burning this cleaner concentrate
- fill up with your favorite fuel* and add another bottle of cleaner plus fuel stalizer if you use..
oil change prior to put away and your done...battery tender one day out of 30 is my routine
* The Only
Non Ethanol Premium in town is at the Conoco located at E.Broadway & E. Front St (just past Burger King)
