Go Back   Z06Vette.com - Corvette Z06 Forum > C5 Z06 Specific Topics > Vendor Sales - C5
Old 08-06-2004, 08:50 PM   #1 (permalink)
Affordable rotating assemblies are just around the corner!
SLP is putting together some low cost but high quality rotating assemblies that can be used with GM's LQ9 iron 6.0-liter block. 383 and 402 cubic inch displacements will be available. Here is a quick rundown of what they are producing and what we will have to offer -
ZL 383 - low compression -
4.000" 4340 forged steel crankshaft, balanced to rotating assembly
3.899" heavy-duty, high-compression 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
383-CID displacement
9:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for forced-induction applications
Includes new rod and crank main bearings
ZL 383 - high compression -
3.899" 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
10.8:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for naturally aspirated applications
ZL 402 - low compression -
4.000" heavy-duty, low-compression, 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
402-CID displacement
ZL 402 - high compression -
4.000" 2618 forged alloy pistons (includes new rings and full-float pin)
6.125" I-beam rods
11.3:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
More details for each of these can be found on our website. Pricing for each kit is $2499.99. We're currently taking pre-orders and should be able to start shipping around the 1st of September.
tbyrne is offline   Reply With Quote
Old 08-07-2004, 06:40 PM   #2 (permalink)
Just iron blocks, no aluminum block assemblies at that price??
07 Z06, Atomic Orange ... mods on the way.
LSC 427 Shelby Cobra, 427 aluminum side oiler (482"), Tremec TKO, coil overs & a Ford 9"..
04 custom cycle, 100ci Revtech, 6sp tranny, custom paint & chrome.
undy is offline   Reply With Quote
Old 08-08-2004, 10:55 PM   #3 (permalink)
They will only be available with iron blocks.
Lunati rotating assemblies on sale! tbyrne Member Sales - Parts & Cars 0 06-21-2004 11:08 AM
Lunati rotating assemblies on sale! tbyrne Vendor Sales - C5 0 06-21-2004 11:07 AM
Lunati rotating assemblies on sale! tbyrne TByrne Motorsports 0 06-21-2004 11:06 AM
Does corner weighting effect alignment?? Change in rear tire effect corner weighting? Silver Bullet C5 Z06 - Pit Road 7 03-13-2003 08:03 PM
Rotating tires? sanz442 C5 Z06 - Grandstand 3 05-09-2001 02:00 PM
