Go Back   Z06Vette.com - Corvette Z06 Forum > C5 Z06 Specific Topics > Vendor Sales - C5
Old 11-21-2004, 06:48 PM   #1 (permalink)
AFR 205cc Heads VS. LS6 Stage II heads
Ok... does anyone have any information as to how the AFR heads flow in comparison to a set of LS6 Stage II heads done by a reputable shop.
For example if you took the AFR heads and ported and polished them, 3 angel valve job, and did the same to the LS6 heads and used the same size valves in both heads, which ones would give the best performance? Flow and velocity.
Launchn is offline   Reply With Quote
Old 11-21-2004, 06:52 PM   #2 (permalink)
From the DYNO reports that I have read. The AFR's produce much better Torque numbers than LS6 ported heads.
Old 11-21-2004, 07:05 PM   #3 (permalink)
MikesZ06's Avatar
In the next couple of weeks I should be able to report the flow differences between the AFR 225's vs the MTI stage 3 heads , but I realize that is not what you're asking.
9.87 at 141mph
& 2007 Black C6 Z06
Old 11-21-2004, 07:07 PM   #4 (permalink)
I interested in this also.
Sig by the Hillbilly!
Old 11-21-2004, 07:12 PM   #5 (permalink)
I dont think thats going to be a fair comprasion. AFR heads out of the box are 2400 with upgraded springs. the whole port job deal is 1600. That makes it cost 4000-1000(for your LS6 heads) 3000 total. While LS6 stage II heads would cost you 1800 max on exchange.
Old 11-21-2004, 07:15 PM   #6 (permalink)
Send a message via AIM to supersmokin650 Send a message via Yahoo to supersmokin650
i was told the 225s were just a sliver to big for the 346...i ended up with stage ii ls6 heads. n e way thought id let u know. even though u asked about the 205s
04z stage 2 block and heads.Ati FMSI (A&A),Goldseriesclutch,Hurstshifter,RKsporthood,Bl ack rims,blackoutlenskit. Last dyno run 605 at the wheels!
supersmokin650 is offline   Reply With Quote
Old 11-21-2004, 07:43 PM   #7 (permalink)
Send a message via AIM to mcss383
The AFR 205's flow the same (and sometimes more) than the 'reputable Stage 2 LS6 heads' and do so with a smaller intake runner size. That means better low-end torque, slightly better idle, slightly better throttle response, etc. Dyno runs have confirmed they make more torque most of the time, and the other qualities are a tried and true 'fact'. Always look for the most flow with the smallest intake runner.
All this stems from intake velocity. You want the highest intake velocity that you can get to keep the fuel suspended in the air while having the highest flow numbers possible.
mcss383 is offline   Reply With Quote
Old 11-21-2004, 08:12 PM   #8 (permalink)
I am interested in the results of this as well!! I'm sure we'll all hear from you at that time.
Old 11-21-2004, 08:13 PM   #9 (permalink)
Z06 WinterFest Coordinator
Kens06's Avatar
Location: Gilbert, AZ Z06 Fest II,III,IV,V WinterFest 1&2
Send a message via AIM to Kens06
If I had it to do over again, I'd go with LS6 stageII!!
205's are pretty rough out of the box and expensive!!
All the numbers people throw around are crap without the whole story!!
You aren't going to slap a pair of 205's on a stock 03 Z and get a 40 HP gain!!
After you mill them to get back to stock CR, clean the CNC machining marks out of the runners and port match gaskets etc MAYBE?
That runs up the purchase price considerably!!
Ken
Kens06 is offline   Reply With Quote
Old 11-21-2004, 08:14 PM   #10 (permalink)
I'm not really looking to compare the price difference, just performance difference. Then I will look at price...
Old 11-21-2004, 08:29 PM   #11 (permalink)
That's a difficult question to answer...better torque numbers ? The only way to confirm which has more power/torque would be to install each set on the same car with the same mods and run on the same dyno to compare.
Thanks MTI
449.8RWHP/432.0RWTQ@MTI
NCM # 26755
RobGrnfld is offline   Reply With Quote
Old 11-21-2004, 08:34 PM   #12 (permalink)
Is that going to happen?
Sanford is online now   Reply With Quote
Old 11-21-2004, 08:41 PM   #13 (permalink)
That's the only way to accurately confirm which heads have more power/torque...otherwise, it's nothing more than a guess.
Old 11-21-2004, 09:38 PM   #14 (permalink)
Surely one of our tuner vendors will or have done this... How about one of the vendors that ports their own heads...
Old 11-22-2004, 07:45 AM   #15 (permalink)
spdrcrj's Avatar
ttt....also interested.
AFR 225s vs Reworked LS6 Heads BLEUBYU C5 Z06 - Pit Road 4 08-30-2005 09:38 AM
AFR heads or LS6? tckylem C5 Z06 - Pit Road 36 04-23-2005 03:14 PM
*IN STOCK* 10 Sets AFR 205cc CNC Heads TTPMatt Vendor Sales - C5 6 01-06-2005 04:08 PM
TTP AFR Stage 3 Equalizer Heads/Cam Package TTPMatt Vendor Sales - C5 2 10-23-2004 06:47 PM
First Impressions - AFR 205cc heads + AFR 224/228 cam. McRat C5 Z06 - Pit Road 79 08-23-2004 04:04 PM
