I figure this will be better in here than in the New Products section -
ATI now has programming available for most of their C5/Z06 kits. Info for each is -
1GK201-SCI - 1997-2004 1997-2003 Intercooled serpentine race kit with the D-1SC (specify LS1 or Z06) - 8# + of boost, 6 rib, twin highflow intercoolers and polished finish on the head unit. Requires larger injectors and programming (not included). Keying the crank is recommended if you are running a modified motor or boost levels above 7#.
1GK206-SCI - 2001-2003 Z06 HO Intercooled system with P-1SC-1 - ATI HO Intercooled System with P-1SC - 6# of boost with twin highflow intercoolers and polished finish on the head unit. This kit also comes with 38# injectors and a hand held programmer. There is an option available to upgrade to the D-1SC head unit. This kit will come with programming if you upgrade to the D-1SC.
1GK211-SCI - 1997-2003 C5 HO Intercooled system with P-1SC-1 - 5 or 7# boost options. Comes with twin highflow intercoolers and polished finish on the head unit. This kit also comes with 38# injectors and a hand held programmer. Keying the crank is recommended if you are running a modified motor or boost levels above 7#. There is an option available to upgrade to the D-1SC head unit. This kit will come with programming if you upgrade to the D-1SC.
The hand held can be deleted from these two packages if you would like to have a custom program made. I rather use 42# injectors with the D-1SC. We can provide you with a set of those so you can delete the 38# from the package and the handheld can be set up for the upgrade.
Tom
