Go Back   Z06Vette.com - Corvette Z06 Forum > C5 Z06 Specific Topics > Vendor Sales - C5
Old 06-05-2002, 11:28 PM   #1 (permalink)
Corvette Store
If you are purchasing anything from this company ensure that you read the fine print. They do not take back numerous items especially electrical no matter if the item if under spec. not as requested or defective.They give you a long stall, a lot of excuses, quote assorted laws and the like but will not take the item back. I enquired before purchasing a HD wire harness if it would handle 140/100 watt bulbs and was assured it would. I also asked if the relays needed mounting, you dont have to as it is "plug and play" was the reply. Upon receiving the harness I couldnt believe that there was only 3" of fusible link and 4 " of 14 ga wire leading to the relays , this meant that you have them hanging down between the battery terminals by the wires so no way can you mount them. The main wire from the relays e to the front of the car is to short therfore you must run it along the side of the fender -it cannot exit the battery box through the bottom where the other wires exit. The unit I recieved was also broken as the headlight doors would not close. I couldnt figure out the problem so took to GM and they said the harness was not up to spec as 40 watt relays are required for my bulbs. I informed Corvette stores and got a lot of run around for over 2 days. So as I had already installed the headlights I had a custom harness made up locally like the one you see on the C5 forum with 40 watt hella relays and complete 10 ga wire,and it works great. I tried to return the harness even saying that I would take other parts in trade but no was the answer and then they started with a lot of other BS including their hiding behind US Laws that mean nothing to me as I am in Canada .
I won't do business with them and I can only advise forum members that they need to read the small print with these guys and if any of you are looking for an under spec harness with a faulty relay and no warrenty give me a shout.
ZEDOH6
01 QS . partion, European Head & Tailights ,Lloyds mats, Alum. dead & gas Pedal, GAGS,extreme exhaust plate,str.wheel decal, c/pit filter, hood seal, Frame Savers,Hurst and Zaino
previously loved Vettes
69 L88 Coupe, 72 454 Coupe,63 a/c SWC, 61 2 top roadster
ZEDOH6 is offline   Reply With Quote
Old 06-06-2002, 08:45 PM   #2 (permalink)
If you have paid by credit card, do what I do and tell the cc company and refuse to pay... They will be asking for there wireharness back shortly. Ship back under there dime only. The cc company's will always back up the customer.
Hello group my name is Mike.... I have a problem.... I am a vetteoholic...
02' Red/Mod Red Z06 (Speedy)
66' Red/Black Roadster 427/390 with #'s match 4sp PS PB PA side pipes (Kicks)
80' Red/Black auto (Red)
ex vettes:
96' Black/Black LT4 (Speedy)
68' Red/Brown roadster 4sp (first vette)
95' White/White-Black roadster auto
79' Yellow/Black auto
My Homepage. Please sign my guest book if you stop by.
mvette is offline   Reply With Quote
Old 06-06-2002, 10:47 PM   #3 (permalink)
Yep thats in the works!
ZEDOH6
Old 06-07-2002, 05:01 AM   #4 (permalink)
Their harness is short in a few areas, but I have had no problems with it and I run 150/100 ceramic PIAA bulbs, if it was longer in a few areas it would make for a better install
Carl V. *****Authorized Zaino Distributor*****
Huntingdon Valley, PA.
2002 Z06 Electron Blue/Mod Red
www.hcvind.com
E-Mail: Zaino@hcvind.com
hcvone is offline   Reply With Quote
Old 06-07-2002, 09:02 AM   #5 (permalink)
Jacob's Avatar
I have seen the harness in question and I would not have it in my vehicle for the high amperage bulb application. On high beam at 150 watts per side, you are drawing 12.5 amps (at 12 volts) per side. This means 25 amps through a single high beam relay. I want at least 12 gauge and preferrably 10 gauge wire to ensure no meltdowns, including connectors.
Maybe I'm being overly conservative, but why cheap out on an $86K (CDN, taxes in) vehicle.
Jacob is offline   Reply With Quote
Old 06-07-2002, 09:18 AM   #6 (permalink)
Send a message via Yahoo to Silver Ghost Send a message via Skype™ to Silver Ghost
You should still have coverage under I believe the Magnusson-Moss Warranty Act, 15 USC, chapter 50. This covers all products over $5. Here is the link: http://uscode.house.gov/DOWNLOAD/15C50.DOC
Eric '08 Machine Silver/Black Z06.
Silver Ghost is offline   Reply With Quote
Old 06-07-2002, 09:23 AM   #7 (permalink)
RG
I'm not sticking up for a vendor because I am one ...and I'll admit I don't know of your specific issue other than what you have told us here and certainly can see your frustration, but, the C/S, Brian(Member-Redshift) has been a supporting vendor from the beginning and I can't say I have seen any issues come up with his products in the past here. Weird he hasn't responded unless he is oiut of town or something.
Did you speak directly with him at the Corvette Store to get this resolved?
RG
RG is offline   Reply With Quote
Old 06-07-2002, 09:41 AM   #8 (permalink)
Originally posted by RG in Dallas
The C/S, Brian(Member-Redshift) has been a supporting vendor from the beginning.
Not anymore!!
Frank QS/Black 2001 Z06
Katech Stage II Heads and Cam, Katech Ported and Polished Throttle Body, 36# Injectors, FLP Headers, High Flow Cats and X-Pipe, Vortex Rammer & Power Duct, BPP Performance Shifter, MSD Wires, Beru Spark Plugs, Lloyds Mats, Chrome Z06 Wheels, Euro Tail Lights
....I AM BONE STOCK!!
Sherylann BLK/Black 2001 Z06
Vortex Rammer & Power Duct, Chrome Z06 Wheels, Lloyds Mats, Shortened stock shifter with MOMO knob
fcalmes is offline   Reply With Quote
Old 06-07-2002, 09:43 AM   #9 (permalink)
RG
Originally posted by fcalmes
Not anymore!!
Didn't see that change to the left. I see it now.
RG
Old 06-08-2002, 05:09 AM   #10 (permalink)
I talked to the company that made the harness, they build harnesses for my engine builder, I told them what lights I was using and asked if the harness would take the load, the owner of the company who my engine builder knows personally said he stand behind his product, that was good enough for me. We did some inferred temp readings after leaving the high beams on for about an hour, other than the glass lenes getting hot we did not see much heat buildup at all in the wiring or the relays. I would not put it in my car if I thought it would cause a problem, but I understand your concerns.
Old 06-08-2002, 07:42 AM   #11 (permalink)
no I have only heard from Eric and Michael.
Old 06-08-2002, 09:27 AM   #12 (permalink)
Gents,
was in a similar situation with a product, called my CC Company........they unformed me, they COULD NOT revoke, charge back on any item.
Unless it was under 30 days from recipt of goods......
Check with your CC Co......
Free Shipping in the Corvette Store Zippy NCM and Bowling Green Plant News 0 11-09-2006 11:40 PM
Is there a Corvette store (goodies) in....... Roadshadowww Southeast 2 01-02-2003 10:29 AM
Somebody have Corvette's Store Euro Lamp kit (Complette wattage) on his Z?? tatoweb Vendor Sales - C5 14 06-05-2002 11:38 PM
Bunch of new stuff at Corvette Store! Redshift Vendor Sales - C5 1 12-03-2001 11:04 PM
Corvette Store - new chrome wheel choices Redshift Vendor Sales - C5 6 07-29-2001 04:34 PM
