Go Back   Z06Vette.com - Corvette Z06 Forum > C5 Z06 Specific Topics > Vendor Sales - C5
Old 10-29-2001, 08:17 AM   #1 (permalink)
Rear Output Shafts from the rear end coming out this week..
Through our problems of breaking rear end output shafts we decided to manufacture them. Made out of a stronger steel strength has been increased by 3 times.
They will be avaliable in 3 to 4 weeks.
Thank You
Ernie
BreathlessPerformance.com
Breathless is offline   Reply With Quote
Old 10-29-2001, 09:57 AM   #2 (permalink)
Cool Ernie! This is a big deal for the guys who are really pushing it. Glad to hear that a solution is coming..
Is this the pinion output shaft?
BrianK is offline   Reply With Quote
Old 10-30-2001, 07:29 AM   #3 (permalink)
The shaft is call a rear end output shaft from the drivers side. We are counting the days to get them in our hands... No more racing till then.
Thanks
Ernie
Old 11-08-2001, 03:19 AM   #4 (permalink)
Send a message via ICQ to ZO SIC Send a message via AIM to ZO SIC
Hey Ernie/Breathless...
Are these available yet? How much are they? I just broke something in the rear of my 5,700 miles '02 Z06 which has a TRIC on it and that's it. Stock street tires at 22 psi with a well prepped track (for once.) Can't belive something snapped :/
Brian
'72 Corvette 454 4-spd Steel Cities Grey "MY DADZ"
'96 Z-28 396" + N2O 6-spd Arctic White "WHYT LIE"
10.78 @ 129mph W/ 1.52 short time
'02 ZO6 QuickSilver/Black "ZO SIC"
ZO SIC is offline   Reply With Quote
Old 11-08-2001, 01:24 PM   #5 (permalink)
We should have them in 2 weeks and cost of about 390.00
The car must of launched good to break that part.
Thanks
Ernie
Old 11-08-2001, 04:18 PM   #6 (permalink)
Does the $390 cover both sides? Are these just the axles that go into the housing and attach to the halfshafts? What material are the stock pieces and what material is your piece going to be? Any other mods to install your pieces, or just bolt in?
The car was going to hook HARD if it didn't break. I usually dump the clutch at 2,200-2,500 rpm (depending on the normally crappy track condition) and still spin. The first time last night I dropped the clutch at 3,000 rpm and bogged badly. So the next time I did it higher, 3,300-3,500 rpm and BANG!!! That was my 1.7-1.8 short time and my 11 second run >
Old 11-09-2001, 07:53 AM   #7 (permalink)
It is only for the drivers side. That has been the weak link. All I can tell you is that the stock piece is made of a low grade material and we have decieded to use a High Tech material that up to 4 times stronger. It is a bolt-on but you need to know what you are doing before you open the rear.
Thank You
Ernie
Will stock trannie, rear end, itc.. be okay running 550hp to the rear wheels? Zmydust C5 Z06 - Forced Induction & Nitrous 20 11-03-2005 06:19 AM
Hardened Output Shafts? MikeS C5 Z06 - Pit Road 17 02-07-2005 05:29 AM
Autocrossing upgrade - Rear discs - Adapting to a solid axle rear end on a Syclone rominga C5 Z06 - Pit Road 14 08-21-2004 10:18 AM
M/T and output shafts Hokie C5 Z06 - Pit Road 7 07-23-2004 12:59 PM
Pagin' MikesZO6 (output shafts) getinofficer C5 Z06 - Pit Road 6 10-13-2002 05:17 PM
