Gearing up for the holidays we are holding a few sales. Any questions please PM me or call us at 973-340-4069 for more information.
TTP Stage 3 Equalizer H/C Combo:
TTP AFR 205cc CNC Heads with Dual Springs, Titanium Retainers - Finish Ported/Polished by TTP
TTP Equalizer V.2 Camshaft
TTP Hardened Chromoly Pushrods
Rollmaster Double Roller Timing Chain
LS6 Oil Pump
SVO 30lb Injectors
GM Steel Headgasket Kit
(2x) GM Headbolt Kits
(2x) AIR Gaskets
(1x) EGR Gasket (If needed)
GM Timing Cover Seal
GM Timing Cover Gasket
(2x) GM Waterpump Gaskets
Installation
LS1 Edit Full Custom Dyno Tuning (Part throttle, wide open throttle, custom timing map, removal of engine codes)
$4799.95
Options:
LSX 90mm Port Matched Intake Manifold - $1100 Installed
TPIS 90mm Throttle Body - $650 Installed (Core Required)
Meziere Electric Water Pump with Relay - $600 Installed
Kooks 1 3/4" LTs with 3" x 2 1/2" X-Pipe - $1200 Installed (Add $260 for Cats)
LG Pro Longtubes with 3” x 3” X-Pipe - $1650 Installed (Add $400 for Cats)
This package just made 474rwhp/429rwtq through a 2003 Z06 with Stock LS6 Intake, Stock Throttle Body, Mez Elec Water Pump, Borla Stingers, Kooks 1 3/4" with 3 x 2 1/2 X-Pipe.
TTP Stage 3 Equalizer Cam Package
TTP "Equalizer" Camshaft (Made 432rwhp on a stock ls6 head car, with full bolt-ons)
Crane Dual Springs, Spring Seats, Titanium Retainers, Valve Stem Seals
TTP Custom Chromoly Hardened Pushrods
Synthetic Oil/Filter Change
All gaskets/bolts necessary
Installation
= $2074.95 + Tax
TTP A&A ATI P1 Supercharger Kit
ATI P1-DSC Supercharger with choice of pulley
Racetronix Fuel System (Or Kenne Bell Boost-A Pump subtract $75)
42lb Bosch Injectors
A&A Upgraded S/C Bracket
Bell Front Mount Custom Intercooler
S/C Belt
3 Fill Bottles S/C Oil
Installation
Synthetic Oil Change/Filter
Dexcool Coolant
LS1Edit Full Custom Dyno Tune
$7500.00 Turn-Key
Options:
Hypertech 160* Thermo: $49.95 Installed
Kooks 1 7/8" , with 3 x 2 1/2" X-Pipe: $1550 Installed (Add Cats $300)
We just installed this kit on a stock 346, stock heads, stock cam, kooks 1 7/8 with 3 x 2 1/2" x-pipe, stock titanium exhaust, stock ls6 intake, 2002 Z06. This kit ran 6-psi, hit 8psi at 6100 and peaked at 9psi at 6300. Here is the power we made with a conservative A/F:
LT Header Installation Specials
Kooks 1 3/4" SS LTs, 3 x 2 1/2 X-Pipe - Installed: $1450 (Add $225 for cats)
LGM Pro LTs with 3 x 2 1/2 X-Pipe - Installed: $1750 (Add $300 for cats)
Free before and after dyno tune with purchase of installed headers. Add a full custom ls1edit dyno tune for only $400 with any of our installed header packages.
SPEC/Exedy Clutch Specials
SPEC Stage 3 X-Pad, Resurface stock flywheel, installed: $900.00
- Upgrade to Stage 3 F-Disc: $110.00
- Upgrade to SPEC Steel Billet Flywheel: $165.00
- Upgrade to SPEC Aluminum Flywheel: $310.00
Exedy Twin Disc Clutch + Chrome-Moly Flywheel Kit, installed: $1900.00
