ATI - PROCHARGER p1sc max boost i get is 5psi why?????
i have done everything in the book , plugged the surge valve, dropped the radiator 4 inches for the strait ram air set up, checked all hoses and intercoolers for cracks, put a huge idler pulley in top of the tensioner insted of the small one, SENT BY ATI FREE OF CHARGE, drilled a new hole on the braket to put an idler where the belt goes down to the water pump to make more belt contact, new gates belt ,katech solid adjustable tensioner ,, no more belt slipping after 3 hard runs
BUT the most i get is 5psi at 6500rpms on a 4.1 pulley that i hear is supposed to make 7to8psi
i want to make the blower set up work but seems imposible right now
so what do i do next, bitch at ATI for a free up grade to a D1? sense i bought this p1 new.?
i'm out of ideas right now
