Old 06-20-2007, 12:36 PM   #1 (permalink)
Send a message via AIM to MrKool Send a message via MSN to MrKool Send a message via Yahoo to MrKool
chirping sound due to bearings? but which bearing?
i have a p1sc with stock pully and tensioner setup and i had the belot out of allignment before so i kept getting the belt chirping but that went away after the car warmed up but not i am getting a mettalic chirping that does not go away even after the is all warmed up and everyone keeps telling me that it is the bearing but which bearing is it? the one inside the SC or the tensioner one and is there a way to tell by not unassembling anything?
thanks
MrKool is offline   Reply With Quote
Old 06-21-2007, 04:51 AM   #2 (permalink)
blown 346's Avatar
It is most likely the either the tensioner or the idler pulley. What I did to tell what pulley was the culprit was to take off the belt, get the pulley in your hand and turn it. You will feel it either roll smooth or have a rough spin to it while its in your hand. The one with the rough spin is the pulley with the bad bearings.
blown 346 is offline   Reply With Quote
Old 06-22-2007, 09:24 PM   #3 (permalink)
well i called procharger and they are sending me a new stage 2 tensioner pulley they had already sent me an idler pulley as well so i will get both these put on.
now does having a Gator belt really does make a diffrence? or should i go with the generic belt that my tuner will put on?
Old 07-15-2007, 02:04 PM   #4 (permalink)
Re: chirping sound due to bearings? but which bearing?
The Gates belts are prone to chirping-The Gatorback should take care of it-but if you want big boost-live with the chirp.
02 Z06 CDN PERF 347 F1C, RPM 4L65E conversion
BEST ET 9.6
BEST MPH 146
vortech is offline   Reply With Quote
How long do bearings last, or should last?? mannygmt2 C5 Z06 - Pit Road 12 05-07-2005 06:52 PM
Chirping Z Dr.Electron C5 Z06 - Pit Road 8 02-07-2005 09:08 PM
Chirping Vortech tensioner? WayneE C5 Z06 - Forced Induction & Nitrous 9 07-17-2004 09:18 PM
engine chirping sound.. zepman C5 Z06 - Pit Road 4 03-10-2002 11:02 PM
Tires Chirping With TC On Zogger C5 Z06 - Grandstand 4 08-27-2001 01:46 PM
