Guys...you need to use common sense FIRST...
1) An IC, oil cooler, tranny cooler, whatever in front of the rad is simply a really BAD idea.
I have an IC in front of mine, with my maggie setup and am just finishing up a diferent system that will remove the ic from blocking the rad.
2) Water temps drive up oil temps until the oil gets hotter, then the opposite occurs. A small thick oil cooler NOT in front of the rad is best. (This is my setup and my temps are as good or better than anyone.)
Also, DON"T use a side mount oil adaptor, they are BS. Why? Because the oem filter will be BEFORE the cooler and if something should break off in the cooler or lines, you can TOAST your engine. Do you want to trust that any of the welds, etc. in a cooler WON't break off over time and vibration, etc...be my guest. I prefer to have my filter as the last item in line before my bearings.
