Old 10-04-2005, 01:55 PM   #1 (permalink)
Engine Wants To Stall When Stopping
I just had a Vortech S/C and McLeod street twin clutch installed on my '01 ZO6. I also had the bottom end forged, added a BBK TB, and dropped the compression to 9:4:1. The engine wants to stall when I'm coming to a stop, especially if it's a quick stop. Because I know the street twin pulls the engine down, I've tried slipping the tranny in neutral when stopping. It helps, sometimes. I watch the tach when stopping, and it usually drops to 150-200 rpm's and then slowly increases to a normal idle, IF it doesn't stall. My tuner is hoping to alter the tune to cure this. I had the same problem on my S/C Z28 when stopping. Is it the tune, IAC, or something else? Thanks.
Rick
ZO6Vette is offline   Reply With Quote
Old 10-04-2005, 01:58 PM   #2 (permalink)
GR8 WHITE's Avatar
I had same problems. I think it is the tune, but i am no expert. FRC TOM may be able to chime in. What I did, was gassed it up a bit when slowing down or slow down more gradually in the mean time. What sucked was trying to make a turn and it stalling out. But then again.....I had bad compression at the time but i do know what your saying. Mine would drop way low and stall on several occasions. Get it checked soon. Would suck if it stalle don a turn with a car riding your tail.....Inevitable for an accident.
Old 10-04-2005, 02:02 PM   #3 (permalink)
It's all in the tune. Take to Andy at A&A
Old 10-04-2005, 02:05 PM   #4 (permalink)
Super Moderator
FRC Tom's Avatar
Idle airflow and throttle follower tables need tweaking.
What are the specs on the cam?
It is what it is
Old 10-04-2005, 02:24 PM   #5 (permalink)
Stock '01 ZO6 cam.
Old 10-04-2005, 02:37 PM   #6 (permalink)
Super Moderator
FRC Tom's Avatar
Take it Andy. He does S/Cs all day long.
Old 10-13-2005, 09:23 PM   #7 (permalink)
Rick
The BBK TB can be a hassle. If you have a scanner, check the throttle position opening (percentage and voltage) at idle and adjust the blade position to specs. IF that checks out then monitor the RAF and make adjustments to compensate, along with the throttle followers.
My Latest 427 Dyno Results
Paradigm is offline   Reply With Quote
Old 10-13-2005, 11:47 PM   #8 (permalink)
Thanks to everyone for all the suggestions. I'll pass this latest to my tuner re the BBK TB.
Rick
Old 10-14-2005, 05:47 AM   #9 (permalink)
Send a message via AIM to benenati379 Send a message via MSN to benenati379 Send a message via Yahoo to benenati379
Hopefully IVO Z06 chimes in. He was having a similar problem but fixed it with a LS2 TB and a re-tune.
Vince
benenati379 is offline   Reply With Quote
Old 10-14-2005, 07:15 AM   #10 (permalink)
Rick
Try this...Unplug the battery overnight, then drive the car next day...I also had a similar problem , and was cured when i did this....But, if this does not work try Andy if in his area, he will fix it..
01 Z06 ATI P1 Procharger 10lbs 383 Forged CnC Heads TPIS
RPS Clutch 626 RWHP--535 RWTQ D1 750 rwhp coming this fall...
Veteran Viet Nam 5th Special Forces Abn
dbvettez061 is offline   Reply With Quote
Old 10-14-2005, 08:45 AM   #11 (permalink)
Idle re-learn may fix it. If not, get it re-tuned. We've seen "issues" with the after market throttle bodies. Some can be fixed, some cannot. The LS2 throttle body seems to work properly every time but the harness needs modification in order to get it to work.
Mikey
mike@Rapid is offline   Reply With Quote
60-0 stopping distances 99cobra2 C5 Z06 - Pit Road 14 10-25-2006 12:29 PM
3000 stall converter in WOW!!! Breathless Vendor Sales - C6 1 12-28-2004 02:19 PM
What do you guys think about a 3600 stall? future C5 owner C5 Z06 - Pit Road 5 08-19-2003 05:39 AM
Lost shifter stopping bolt and nut... urpow C5 Z06 - Pit Road 3 04-20-2003 11:34 PM
So my Yank stall is on the way! quick98 The Garage 5 03-01-2003 01:04 PM
