Old 08-01-2007, 09:17 AM   #1 (permalink)
chimazo's Avatar
Finished & tuned w/dyno #'s! 562/467 (long)
I literally finished buttoning up the installation of my old-style P1SC Procharger Saturday morning so I could make my appointment with the tuner an hour away in Gettysburg, PA. I started it for the first time and went through the process of adding coolant and waiting to see if the fans/t-stat were working properly, listening for funny noises, etc... Of course, I had the mandatory coolant leak which fortunately was just a hoseclamp I neglected to tighten. My first (test) drive was the drive to PA and I didn't even have time to install any gauges!
I drove up on the stock injectors, never going above 2000rpm. The temp outside was 95F but coolant temps stayed at a solid 194-196F with the A/C on, even though I have the radiator reclined and don't have the centerpiece of the airdam installed. I DID make a makeshift "shroud" and made my own piping setup for the blower to resemble the newer kits. Once at the shop, we also pulled out the line that goes from behind the TB to the valley pan and vented it to the ground.
Once I made it to the shop (after having to drive like an old woman through thunderstorms on my BFG KD's), I installed the 60LB Siemens injectors I brought along. The tuner I used is named Jeremy Formatto and he travels around the country tuning cars with cooperating shops. He is quite popular with the GTO crowd and is a nice guy, very accessable, will explain any question you might have about what he is doing to your car, and does NOT lock the tune. He loaded a base tune from another car that had a similar setup and we loaded the car on the dyno. All it needed was three pulls to richen it up a bit and pull some timing. He also road tested it with me while monitoring everything. We had ZERO knock retard during full throttle blasts. The temp outside was 87F and the results are below. Very happy and until you get on it, you would never know the car wasn't stock, except for the very faint whine from the blower.
chimazo is offline   Reply With Quote
Old 08-01-2007, 09:49 AM   #2 (permalink)
KCMAGS's Avatar
Re: Finished & tuned w/dyno #'s! 562/467 (long)
Very nice!!!! I would recommend replacing those screw clamps with t-bolt clamps. Nice work.
Old 08-01-2007, 02:59 PM   #3 (permalink)
chimazo's Avatar
Yeah, I ordered a bunch of good clamps in the wrong sizes, plus then I went with a larger tube so now I am stuck with a bunch that will fit a 3" tube.
Old 08-02-2007, 07:38 AM   #4 (permalink)
LJo
LJo's Avatar
Please tell me you disconnected the line that I circled and blocked it at the intake manifold and vented the crank case to the air filter?
LJo is offline   Reply With Quote
Old 08-02-2007, 07:59 AM   #5 (permalink)
chimazo's Avatar
Yep, pulled the line out that you circled, capped the end behind the TB and used hose pointed to the ground to vent the other end.
Old 08-02-2007, 08:09 AM   #6 (permalink)
LJo
LJo's Avatar
You could also vent this location if you see you are getting excessive crank case pressures.
Old 08-22-2007, 09:30 PM   #7 (permalink)
Nice!!
2004 Machine Silver Z06 ATI Procharger STGII. FOR SALE
valdeztke is offline   Reply With Quote
FS: 2001 QS Z06 w/mild mods & A&A tuned m5guy Member Sales - Parts & Cars 3 05-18-2006 07:08 PM
For only an intake, yet another STRONG A&A tuned z06. *dyno sheet* DitchTehFish C5 Z06 - Grandstand 5 04-22-2006 04:14 AM
Dyno Tuned the Z Yesterday Jay'szo6 C5 Z06 - Tuning & Electronics 16 11-19-2005 09:27 PM
Got the Z Dyno Tuned...have a question... Miguel C5 Z06 - Tuning & Electronics 12 09-18-2004 11:41 AM
Where can I get my car dyno tuned? extremecorvette C5 Z06 - Grandstand 2 07-21-2004 08:07 AM
