Old 12-05-2007, 05:13 PM   #1 (permalink)
Rob G's Avatar
How much boost for stock bottom end 03; Z
And for how long, say 10 psi 3-4 sec?
Rob G is offline   Reply With Quote
Old 12-05-2007, 05:51 PM   #2 (permalink)
Super Moderator
FRC Tom's Avatar
Re: How much boost for stock bottom end 03; Z
bottom end can handle 10lbs but the CR of the Z06 wont have the pistons lasting very long with 10lbs of boost unless you use meth injection.
6lbs for a stock Z.
It is what it is
Old 12-05-2007, 06:08 PM   #3 (permalink)
Rob G's Avatar
where i get meth kit?
Old 12-05-2007, 06:32 PM   #4 (permalink)
Super Moderator
FRC Tom's Avatar
Eastcoast Supercharger out of Jersey has a good kit.
Google them.
Old 12-06-2007, 11:01 AM   #5 (permalink)
I agree. Stay at 6 lbs and under.
Old 12-11-2007, 04:33 PM   #6 (permalink)
will82's Avatar
Change heads and sell the ls6 heads or have the combustion chambers on your ls6 heads opened up a little. If you lower your compression ratio enough, the stock pistons can handle 9psi or more. Meth is a good idea as well.
Sig by GR8 White
ECS ProCharger | B&B Headers | O/R X-Pipe | RPM Transmission & Differential
will82 is offline   Reply With Quote
Old 12-11-2007, 08:45 PM   #7 (permalink)
Please be more specific. I am considering the purchase of Patriot stage 3 heads and want to lower my compression and turn up the boost.
02 EB Z06, STS GT32's @7lbs, FMIC, 60lb Motrons, HPTuners and a few other goodies.
jmoody66 is offline   Reply With Quote
Old 12-11-2007, 08:54 PM   #8 (permalink)
will82's Avatar
Well then get their stage 3 LQ9 heads instead of stage 3 ls6 heads. LQ9 heads are very similar to ls6 heads, but have larger combustion chambers than ls6 or even ls1 heads, and will lower your compression ratio.
What size (CID) engine do you have? Stage 3 Patriot heads are designed with large bore motors in mind. If you're still stock displacement, you may want to go with stage 2 heads, which Patriot designed for 3.905 bore.
***edited***
Not totally sure, so probably best to ask them.
Old 12-11-2007, 09:24 PM   #9 (permalink)
Send a message via AIM to CraZee ZO6
6-7lbs MAX or you can count the motors life in weeks on your fingers.
2003 C5 ZO6
STOCK LS6 346 cubes H/C
Vette Doctors RX500
CraZee ZO6 is offline   Reply With Quote
Old 12-12-2007, 09:24 AM   #10 (permalink)
Super Moderator
FRC Tom's Avatar
The LQ9s are 71cc and flow just as good as the 64cc LS6 head, this will bring your CR down to 9.6:1.
These heads can bo found on E-Bay for small $$.
Old 12-12-2007, 05:09 PM   #11 (permalink)
***edited***
My block is stock and I want to reduce my chance of blowing things up until I take the plunge and just build out the block. I called a vendor on ebay and was told that the LQ9 heads would NOT work because of the bore size....so Im lost because I hear diff things.
Also since I am running twin turbos I figured I would be able to take advantage of stage 3 heads....please everyone lead me into the right combination....Im no pro.
Old 12-17-2007, 09:44 PM   #12 (permalink)
I ran my Kenne Bell at 8 to 9# for a year and a half making 580rwhp with no issues.
OBXFunn is offline   Reply With Quote
9.94 stock bottom c5 03cobra Quarter Mile 5 12-23-2007 10:45 PM
Getting a stock bottom end Z06 into the 10's... MidnightHour C5 Z06 - Pit Road 11 02-23-2006 02:59 PM
Top 10 Fastest in the 1/8 On Stock f1's all-motor, Stock bottom-end. HcBlackZo6 Racing 27 06-08-2005 09:53 PM
Stock Bottom and High HP who has it? PimpinZ06 C5 Z06 - Pit Road 2 04-22-2004 06:16 AM
ATI with Stock Bottom end AWSM_06 C5 Z06 - Pit Road 17 08-16-2002 01:20 PM
