Old 09-23-2008, 08:31 PM   #1 (permalink)
DRAGKKSL's Avatar
Need help LS7 in to a C5 ZO6 or LS6 twin turbo
what do you guys think will be the best set up i want to put an LS7 on my C5 ZO6 but i want to either put a twin turbo set up or a supercharger, i mean i love the N/A all motor sound but it just isn't enough power. or should i just keep my LS6 and do the twin turbo setup
DRAGKKSL is offline   Reply With Quote
Old 09-23-2008, 08:48 PM   #2 (permalink)
PerforminNorman's Avatar
Re: Need help LS7 in to a C5 ZO6 or LS6 twin turbo
I vote TT setup on your LS6.
Come to the Z06 Fest!
Performin' Norman
Old 09-24-2008, 01:31 PM   #3 (permalink)
RocketSled's Avatar
You'll get more power and better MPG from a TT LS6 than you'd get from a NA LS7. And it'll arguably be less work, since you won't have to pull motors or screw with the electronics to adapt the C5's computer to the LS7's sensors.
C6!
Old 09-24-2008, 01:34 PM   #4 (permalink)
Location: Edgewater, MD Z06 Fests 2,3,4,5,6,7 Ocean & WinterFest 1&2
Gotta go with the experience on this one!!! I like the idea!
NCM # 23306 Fest Member 2, 3, 4, 5, 6, 7 Ocean & WinterFest 1 & 2
Old 09-24-2008, 01:52 PM   #5 (permalink)
Thanks Mike. With the exception that some bone head stuck the wrong engine in my car. LS2s are for C6s, not C5s.
Old 09-24-2008, 04:34 PM   #6 (permalink)
Z1LE's Avatar
Why not just TT an LS7? Then you get the best of both worlds!
Z1LE is offline   Reply With Quote
Old 09-25-2008, 08:06 PM   #7 (permalink)
I've got 500rwhp with a LS3 418ci build, headers 3" exhaust and stock ti. I would think if planned a little better I could had 30 more hp. What are you looking for in HP numbers? I keep up with Norm somewhat, but well ahead of Terry in his stock C6 Z (you have to know Terry)...
PaulS is online now   Reply With Quote
Old 09-27-2008, 05:07 PM   #8 (permalink)
DRAGKKSL's Avatar
thanks i need to do more research
Old 09-27-2008, 05:16 PM   #9 (permalink)
DRAGKKSL's Avatar
if i do an stroker kit to the LS6 u guys think it will hold the tt i am looking for 1200hp
Old 10-02-2008, 11:50 AM   #10 (permalink)
For that kind of HP you might want to think about getting with SLP to build the motor for TT application. I have the SLP402 iron block LS1 low compression stroker motor in my FRC with the STS twins. I don't think I would put that much power to ANYTHING stock, you would just wind up buying another motor eventually anyway. Just my 2 cents.
99TTFRC is offline   Reply With Quote
Old 10-02-2008, 11:59 AM   #11 (permalink)
There was one member here who had a NJ tuner build a forged 346 turbo car that put down just over 1000 rwhp......but that was more than just a stroker kit.......and a one of a kind so far that I know of.
1200 hp is a huge number.....is this going to be a dyno queen?? That'll be a real handful to keep under control on the street...even in dry conditions.
Good luck on this build...keep us posted on you progress.
Old 10-04-2008, 04:44 PM   #12 (permalink)
Jofu's Avatar
Not sure if you care about this or not, but if going the TT route, I believe the STS Turbo kit is still the only CARB legal one out there, unless things have changed in the last 2 years...
Geoff
Jofu is offline   Reply With Quote
Old 10-05-2008, 12:22 PM   #13 (permalink)
I think JoFu is right about the carb legal STS Kit that is needed for Ca. If you have any questions about that kit, I can answer them for you. I also have pics of the install on my FRC if you are interested. It is a clean kit for sure. I am waiting on my heads to come in from SLP to find out what my numbers are going to be, and I will post them after the dyno.
Single Turbo vs Twin Turbo ('02 Z/06) HELP 1BADRIDE C5 Z06 - Forced Induction & Nitrous 24 10-09-2008 07:09 PM
APS Corvette C6 ZO6 LS7 twin turbo kit trev0006 C6 Z06 - Forced Induction & Nitrous 12 02-09-2008 12:07 PM
SEMA 2007 Spotlight: APS C6 ZO6 LS7 twin turbo kit El Calor Z06Vette News 0 11-11-2007 05:43 PM
Photos: STS Twin Turbo on a ZO6 GR8 WHITE The Garage 3 11-28-2005 11:33 AM
Zo6 Twin Turbo? Butch Z06 C5 Z06 - Grandstand 5 06-12-2002 08:09 AM
