New to C5 Vettes, what is max bolt-on HP? - Z06Vette.com - Corvette Z06 Forum
post #1 of 16 (permalink) Old 01-13-2005, 08:24 PM Thread Starter
Hi everyone.....
I might be buying a later model C5 '00-up.
I grew up around turbocharged Audi's, VW's, and Porsches, so I'm used to 20+ psi of boost to get some quick 1/4 mile times.
A friend of mine has a '01 Z06, and I was very impressed with it.
He claims 515 (flywheel) HP with just a cam, full exhaust, larger throttle, reprogrammed ECU, etc. He runs 11.7 @ 126
I also have another friend with a Lingenfelter Twin Turbo Vette ('00 model), and it is SCARY with just 7 psi! I have other friends with Supras with 28psi of boost, but they don't even come close to the LPE Vette!
I'm curious how much (bolt-on, stock block) HP one of these Vettes can take before tearing the engine apart..........
I would love to have a 500whp '00-up Vette.........Is that possible with bolt-ons?
Thanks!
d993 is offline
post #2 of 16 (permalink) Old 01-13-2005, 08:31 PM
It all depends on what you consider a bolt on. A Supercharger is a bolted on external to the motor, but not what I call a bolt on. To me bolts are headers, air intake etc. 500 RWHP it not obtainable from bolt-ons.
IT L GO is offline
post #3 of 16 (permalink) Old 01-13-2005, 08:37 PM Thread Starter
By bolt-on, I meant on a motor with stock internals, including stock compression ratio.
d993 is offline
post #4 of 16 (permalink) Old 01-13-2005, 08:37 PM
390 RWHP is about the max from bolt-ons (headers intake, tuning)
480 RWHP cam, heads and headers
550 plus from a 427 stroker all motor
500 to 600 RWHP from a Blower
IT L GO is offline
post #5 of 16 (permalink) Old 01-13-2005, 08:41 PM Thread Starter
If I would bolt on a SC (I have had good success with Whipple SCs), how much boost can I run without changing pistons, rods, etc?
How much HP can I expect? (assuming high flow intake and exhaust)
d993 is offline
post #6 of 16 (permalink) Old 01-13-2005, 08:49 PM
Z06 Power Adder Authority
Unfortunately Whipple does not make a blower that will fit under even a modified Vette hood. It's just too tall. :( Magnacharger makes one (Eaton-built blower), if you're looking for a positive displacement blower.
Keep the boost in the 5-6psi range (on a Z06 which has 10.5:1 CR) or 7+psi on an LS1 C5 (10.0:1 CR) and you should make 480-500+rwhp (Z06) and have no issues.
The centrifugal blowers (Vortech/ATI) will make more peak hp at the same boost level since they are more efficient in the higher rpm range.
'02 Z06 (654rwhp/621rwtq)...LPE/21CMC Stage 2 Twin Turbo
'05 RAM SRT-10 RC (448rwhp)
'09 Shelby GT500 'vert (578rwhp)
'04 SVT Lightning...son's ride now, but I hold the note!
'08 Denali 6.2...wife's ride
WA 2 FST is offline
post #7 of 16 (permalink) Old 01-13-2005, 09:47 PM Thread Starter
Thanks for the info..............
Anyone have 1/4 times and trap speeds with any of these SC set-ups?
What about nitrous? What's the most than can be used (individual port)
d993 is offline
post #8 of 16 (permalink) Old 01-13-2005, 09:53 PM
case2307's Avatar
Most people don't spray any more than a 100 shot on a stock motor.
Si vis pacem, para bellum.
case2307 is offline
post #9 of 16 (permalink) Old 01-14-2005, 06:11 AM
Send a message via AIM to WayneE
You can safely spray a 150 shot, IMO.
I have a set of headers, cold air intake and a Vortech blower. Power is in my sig. I've only been to the track once, but was slip sliding all over the place and couldn't get into the gas until 3rd gear. 11.30@129. Best prior to the blower was 11.96@118.5.
I'll be bolting on some sticky tires in the spring to run some 10s
WayneE is offline
post #10 of 16 (permalink) Old 01-14-2005, 08:04 AM
You might come damn close to 500rw with every bolt-on imaginable (LSX intake, Large (Read: LARGE) cam, Heads, headers, catback, intake, pullies, throttle body, etc). I think there's a car or two (if memory serves) that made it to that degree. More likely is ~480rw with all those goodies. 440-450rw seems to be about right for most "BIG" daily applications with just the forementioned minus intake/throttle body combo.
2008 MS Z06
1957 Corvette
2004 Red Yamaha R1
2003 QS Z06 with ModRed interior- Gone to a new home now, but never forgotten
Jagrmaister is offline
post #11 of 16 (permalink) Old 01-14-2005, 08:11 AM
GR8 WHITE's Avatar
Way2fast
WHAT DO YOU MEAN BY THIS?
"Keep the boost in the 5-6psi range (on a Z06 which has 10.5:1 CR) or 7+psi on an LS1 C5 (10.0:1 CR) and you should make 480-500+rwhp (Z06) and have no issues."
I have a stock C5 (2000), so what is recommended safe PSI for me? I was looking toward the ATI Procharger from Andy.
Thanks
GR8 WHITE is offline
post #12 of 16 (permalink) Old 01-14-2005, 09:15 AM
I was referring to the Magnacharger setup.
The ATI and Vortech blowers can run a little more boost...I'm just trying to steer the guy to the conservative side. Since a centrifugal blower builds boost with rpm, its only at its peak static compression ratio for a very short time (as you approach the shift point), so you can get away with a little more max boost... maybe 8-9psi in some cases. Of course, you're not making this kind of boost over the entire rev range, and that's actually an advantage as far as reliability is concerned (although power under the curve is less).
Quite honestly, I know some people run more than that with 10:1+ CR, but I do not believe its wise for the longevity of the engine. You can drown the motor in fuel, retard timing, etc all you want... once the maximum static compression is reached for a given octane of fuel... you're SOL. It will still have detonation. It may not be audible to the human ear, but it can be inaudible and still be doing damage.
If you want to run some serious boost and get the most potential out of the blower, then it requires lower base CR. 8.5:1-9.0:1 for a street car that needs to pass emissions is best.
I'm not trying to steer you, or anyone, away from Andy's stuff. He has a great reputation. Go for it!
WA 2 FST is offline
post #13 of 16 (permalink) Old 01-14-2005, 05:48 PM
[QUOTE=d993]Hi everyone.....
Just food for thought. Most of the 2003 cars and later, except for the very early 03's have a fuel tank/delivery system that is tougher to tame than with than the earlier cars. Not trying to slam the later cars but if you could find a low mileage cream puff 2002 or earlier you would have an easier time with fuel delivery. If you want over approx 500 rwhp with forced induction then fuel delivery and injectors upgrade is a must. My 2 cents. Good hunting.
RICK 99 FRC, LPE C5-R 427 TT, LPE Minitubs, Boost Controller. A ZO-6 Prototype. Born: 12/3/98
725 RWHP 800 TQ
Sack Rat TT is offline
post #14 of 16 (permalink) Old 01-14-2005, 06:37 PM
blower experience
I had a 95 Z28 in 95 and SC'ed it in 96 with a procharger I had Bob Norwood do a lot of custom work to the system including modification to the FMU and the intercooler.
Now, I am not sure if you guys have heard of Bob Norwood, he does a lot of twin turbo ferrari but this guy takes a car all the way to the edge of disaster then one step past it. He had explained to me that as long as you have the air/fuel ratios and the spark your engine wouldn't know it was blown.
He told me since I was only needing ~65lbs fuel pressure @9lbs boost at the intake (stock bottom end) I could spin the blower harder.
Having been offered the opportunity to spin it harder and keep it in line air/fuel wise who could turn that down? We put it on the CPU and spun it to 13lbs boost at the blower and 11lbs at the intake (stock bottom end)! In order to do this I had to run 85lbs fuel pressure.
Like I said one step past the edge of disaster. 4500 miles later no more motor. I took the SC'er off and sold it. I went back to Bob and he told me I was an idiot if I would have just cut the boost to 6-7 psi it'll last forever for less than any other mod for the money other than NOS.
Now I have had the pleasure of listening to the whistle on one car and I think you should be very careful on how greedy you get when playing with a pressurized motor that wasn't built that way from the factory unless you plan to tear it down at some point (most would say a long time if you don't get too greedy) I think Iím going to stay NA with the Z06.
24heursz06 is offline
post #15 of 16 (permalink) Old 01-14-2005, 06:39 PM
PriestYates's Avatar
Go old school and cut a hole in the hood!
02' Z06 - Not modded enough.....
78' El Camino - B&B 383 stroker, B&M 400 w/ 2500 stall, custom headers and exhaust, lowered and tubbed, 12 Bolt 3.73 posi - SOLD
PriestYates is offline
  Z06Vette.com - Corvette Z06 Forum > C5 Z06 Specific Topics > C5 Z06 - Forced Induction & Nitrous
Max Rwhp Bolt-ons Z06??? jaredwayt C5 Z06 - Pit Road 8 09-14-2005 05:36 AM
LED Max'd out sjgumshoe C5 Z06 - Pit Road 6 07-09-2005 04:27 PM
Z06 Injector's max HP jz06man C5 Z06 - Pit Road 15 03-22-2005 07:19 PM
max speed in turns spytech Racing 27 11-24-2002 03:46 PM
Z06 max speed? urpow Racing 31 11-21-2002 08:47 PM
