Old 05-02-2008, 10:03 PM   #1 (permalink)
!!new Startup/dropped Oil Pressure!!
ey guys, just fired up the ls6 for the first time tonight, SOUUNDED SOO GOOOD....I let it run for a couple minutes and the shut it down to fix a couple leaks, then started it again and let it run for probaby ten minutes. I have an aftermarkte high volume oil pump from lingenfelter, and I noticed that my oil pressure was reading betweent 118 and 130!! I thought it would go down as the engine warmed up, as I backed the car out I saw that my ins. cluster says service engine soon, and low and behold I have 0 oil pressure....what could be wrong??
Dustin
Boosted04Z06 is offline   Reply With Quote
Old 05-03-2008, 06:41 AM   #2 (permalink)
robls6's Avatar
Re: !!new Startup/dropped Oil Pressure!!
sounds to me like the excessive pressure messed up the sending unit. Try putting a mechanical gauge on it to see what kind of pressure you have when the car gets hot.
2003 MY Z06 - Lunati custom cam, LG headers, Blackwing, McLeod dual disc, RPM stage V trans
409 RWHP
Old 05-03-2008, 10:23 AM   #3 (permalink)
Dustin,
I agree with Rob. 118-130 is way too high. The stock oil pump relief lifts at about 75 psi to port oil back to the pan to protect the engine from excessive oil pressure. I'd ask what the relief is set at for your aftermarket unit. If it is as high as 130 psi, I think that is very excessive.
Its possible that as Rob guesses that you have damaged the sending unit. Only way to know for sure is a mechanical unit.
Good luck sorting this out.
Customized DIC Startup Stogo C6 Z06 - Pit Road 13 12-01-2005 02:11 PM
Charge system fault @ startup bigcat39 C5 Z06 - Pit Road 4 06-03-2005 09:03 AM
Strange Startup Characteristics dilly03 C5 Z06 - Pit Road 14 05-16-2005 11:13 AM
Whistle sound on startup? rpallas C5 Z06 - Grandstand 7 02-04-2003 06:08 AM
----Second Update----**Update-8/22/01** Oil pressure dropped to 8 PSI??? MARZ06 C5 Z06 - Pit Road 16 03-14-2002 02:13 AM
