Old 06-21-2007, 04:48 AM   #1 (permalink)
blown 346's Avatar
ProCharged D1SC with 10LBS of boost??
I have a 01 Z with a mild blower cam, LG longtubes,GHL catback, and the A&A kit using a D1SC.
I have a 8 LB pulley on the blower, and with the new FMIC setup I would see about a 2 PSI increase of boost.
What dyno numbers should I be expecting when I get the car tuned.
blown 346 is offline   Reply With Quote
Old 06-21-2007, 07:19 AM   #2 (permalink)
KCMAGS's Avatar
550/480
Old 06-21-2007, 11:39 AM   #3 (permalink)
550 on a high comp motor with a blower cam and exhaust?
Try 650.
Old 06-21-2007, 01:23 PM   #4 (permalink)
KCMAGS's Avatar
Try 650.
OK...but not for long. IMO
Old 06-21-2007, 01:23 PM   #5 (permalink)
If you want to lean on the tune it can make some real power. D1's are a good size blower - plenty for 700 rwhp on a forged lower end.
mdhmi is offline   Reply With Quote
Old 06-21-2007, 01:51 PM   #6 (permalink)
MikesZ06's Avatar
I'm thinking 1000rw....
Old 06-21-2007, 02:03 PM   #7 (permalink)
Oh absolutely. I wouldnt set a car up like that unless I had the built motor waiting to go in, but he asked what he would make, so.....
Old 06-21-2007, 02:09 PM   #8 (permalink)
KCMAGS's Avatar
Old 06-21-2007, 03:02 PM   #9 (permalink)
blown 346's Avatar
No forged motor yet, Im planning on runnimg some meth as well. I have beeen told it is used for a safeway for guys who still have stock bottom ends.
Old 06-21-2007, 03:20 PM   #10 (permalink)
KCMAGS's Avatar
Yes...The meth would not be a bad idea. I have an ECS kit that I'm very happy with & Andy @ A&A just released a very nice kit also.
Old 06-21-2007, 04:09 PM   #11 (permalink)
blown 346's Avatar
I saw that kit that he has, for the setup it is going to be a hot item. Should I wait to get the car tuned until I get the methanol?
Old 07-01-2007, 06:41 AM   #12 (permalink)
If I remember correctly, when I did my ECS Paxton setup, they told me if I added meth I would need another tune. So I did them at the same time. They use one port until about 650 HP so and then switch to two after that.
2003 Blk/Blk 541 rwhp/477 rwtq | ECS Paxton Novi | Alcohol Injection | Racetronix Fuel system | 60# Motron Injectors | Textralia Clutch | DTE Brace | Hardened Left shaft | American Racing Headers | Borla Stinger 4-Tip | B&M Ripper shifter | lots of other little stuff.
HeadHunter is offline   Reply With Quote
Old 07-02-2007, 05:54 PM   #13 (permalink)
Send a message via AIM to MrKool Send a message via MSN to MrKool Send a message via Yahoo to MrKool
i am running a P1 with about 7 lbs and i have 510 / 436 so if you have a D1 with 10 lbs you should def be around 600 / 500
MrKool is offline   Reply With Quote
Old 07-12-2007, 08:34 AM   #14 (permalink)
Re: ProCharged D1SC with 10LBS of boost??
My buddy has a D1 and 402 set up with 10lbs. He's putting down 700 rwhp on 91 Octane. With a smaller motor (346) you should be in the 550-600 rwhp range.
Tony
No car for now
Past Vettes:
02 MY Z06 554 rwhp
02 QS Z06 6XX rwhp
Z O SICK is offline   Reply With Quote
Old 07-12-2007, 09:30 AM   #15 (permalink)
I would say about 550-575 rwhp...I am running 630rwhp with an ECS 383 and my old wimpy P1 blower , which will be upgraded this fall to a D1/8rib......Looking for 750 rwhp!!
01 Z06 ATI P1 Procharger 10lbs 383 Forged CnC Heads TPIS
RPS Clutch 626 RWHP--535 RWTQ D1 750 rwhp coming this fall...
Veteran Viet Nam 5th Special Forces Abn
dbvettez061 is offline   Reply With Quote
Question about D1SC procharger? z06_23_45 C5 Z06 - Forced Induction & Nitrous 16 11-30-2005 11:21 AM
ATI: P1SC or D1SC? GR8 WHITE C5 Z06 - Forced Induction & Nitrous 29 06-26-2005 01:04 PM
F/S D1SC Procharger and other parts srhodes Member Sales - Parts & Cars 9 10-08-2004 05:35 PM
Nitrous bottle size 15lb or two 10lbs tabratton C5 Z06 - Pit Road 4 07-20-2003 11:55 AM
Per Moderators Request: What it is like to drive a Z w/10lbs of boost jnation C5 Z06 - Grandstand 87 09-19-2002 10:04 PM
