Re: Procharger belt squeak
Originally Posted by BoostedVette01
I have an A@A D1sc procharger system and have been having problems with the belt squeaking. It is the 8 rib setup. I am currently running around 18psi by using the smallest sc pulley and the largest crank pulley I could buy. The belt is in line (tested it with a laser) But I can't get the belt to stop squeaking. It only does it after the first 75-100 miles of a new one being installed. At wot I am not losing boost pressure any suggestions or someone who has gone through this please help!!!!
I would suggest going to the ATI stage 2 brackett. That is alot of boost and if it is the same bracket that I had from A&A with the extra pulleys for added belt rap it just wasn't enough. No problems after going from 6 rib to 8 rib and the stage 2 bracket. Hope this helps. Belt issues seem to be voodoo on this forum but as MikesZ06 pointed out it is hard/impossible to diagnose belt issues without having the car present.
02' Z06 EB/EB 4,400 miles, Longtubes, Off-road X-pipe, Pypes X-back, Blackwing CAI, Comp. Cam 238/240-.605/.609-112LSA, Comp. Beehive Springs, Comp. Titanium Retainers, Comp. Hardened Perf. Push Rods, Comp. Billet Double Roller Timing Chain, Hurst Short Throw, Cray 19"/20" w/ Toyo Proxes4 265/30/19's & 295/30/20's
