Old 12-15-2006, 11:21 PM   #1 (permalink)
Safe Limit with Boost
I would like to know what are or could be a safe limit to a stock bottom end... I'm looking into a turbo setup..
I'm heard everything from 500rwhp-600rwhp and then some..
I'm planning on changing the head to lower compression around 9.5-9.9..
Thanks!
04 Torch Red Z06, TTi X Stage Twin Turbos, Patriot stage 2 ,062 Vinici cam, DTE Brace, LS7 Clutch, Rear Partition,V-1,Corsa Indy Cat=Back, T-Ported,3M Clear Bra,Chrome Z06 Wheels,Wilwood 6 Piston with GT Rotors.
jz06man is offline   Reply With Quote
Old 12-15-2006, 11:52 PM   #2 (permalink)
You should be fine up to 12 PSI and 650 RWHP with complete stock engine. Im boosting 10 Psi 627 RWHP 500RWTQ Methanol injection..and have no problems. Also running at that high HP you have to have meth.
Goodluck!
72stroker is offline   Reply With Quote
Old 12-16-2006, 10:09 AM   #3 (permalink)
TT Z06's Avatar
I ran 10psi with meth above 5psi on stock LS6 with no adverse side effects whatsever. I have upgraded my motor soley for my quest for sic fun, but I still have the perfectly running LS6 long block. Haven't decided whether to sell it or keep it for matching numbers. Depends on how long I plan to keep the c5 I guess.
850HP MTI STS 402 Twin Turbo Z06
TT Z06 is offline   Reply With Quote
Old 12-16-2006, 06:42 PM   #4 (permalink)
I believe the plan is to run around 8psi and not meth with the Twin Turbos.... I'm told this should yield 550-600rwhp...
Old 12-17-2006, 01:47 AM   #5 (permalink)
TT Z06's Avatar
Just advice, and just from what I've been told, but hope it helps.
Different pistons is the correct way to lower compression, thicker head gaskets is a nono, modified heads is a compromise/patch but much easier than pistons to get at.
Meth above 5psi cools the mix, keeps the temp down, and helps prevent detonation. meth kit is 5 cnotes, but may prevent fatal engine failure. I haven't seen one implode or melt myself but I got insurance and ran meth.
As for what I've seen with my own eyes,
At 8psi my stock ls6 twin hit 551 on the dyno, 598 at 10psi. I still have these dyno sheets.
Old 12-17-2006, 08:18 AM   #6 (permalink)
MikesZ06's Avatar
I think that is an overstatement.
Both heads with larger combustion chambers and dished pistons are appropriate methods of lowering your C/R....either seperate or in combination.
9.87 at 141mph
& 2007 Black C6 Z06
Old 12-17-2006, 10:26 AM   #7 (permalink)
TT Z06's Avatar
Thanks for catching that Mike, I concur. It was thicker gaskets that I had heard would cause problems and was told to avoid that technique. While I do have custom heads, I believe most, if not all, of the lowering on mine was done with the pistons since it made sense to forge everything down there anyway.
Old 12-17-2006, 06:34 PM   #8 (permalink)
Iam going with a custom head to bring compression down....
Old 12-21-2006, 03:12 PM   #9 (permalink)
I am at 580rwhp at 8# and running meth.
OBXFunn is offline   Reply With Quote
Old 12-21-2006, 05:01 PM   #10 (permalink)
On stock internals, enough boost to yield 500-550 rwhp. After that you can throw longevity out the window. I've read that plenty of guys are doing OK with more rwhp on stock internals, but I've also read that plenty have lost it as well. If you stay around 500, there won't be an issue. I ran at 575rwhp for quite a while with no issues, but then maybe I was just lucky!
01 QS/Blk, A&A LS2 402 stroker w/ Vortech T-trim 723rwhp 700rwtq, RPM Tranny.
Zrod is offline   Reply With Quote
Old 12-21-2006, 10:15 PM   #11 (permalink)
is it a differance if your running say, 550rwhp on a supercharger or 550rwhp on a turbo???
I would assume 550 on a super is tougher on an engine than 550 with a turbo..
550/ .85 =647 at crank + 60-80hp to run the super is about 707 to 727 at the crank vs the turbo is still making around 647 crank hp....
I'm not sure just asking the question.... it seems the super is/might be harder on the engine....
Old 12-22-2006, 02:42 AM   #12 (permalink)
TT Z06's Avatar
Yea, I bet some motors are just right, others may have a flaw only revealed under stress.
Old 12-22-2006, 12:29 PM   #13 (permalink)
Zrod- How long did you run the car without an issue???
I forged the motor, but not now with the turbo install. If i can get 1 or 2 season (5k-10K miles) out of her before the forging, i'll be real happy...
Old 12-22-2006, 04:42 PM   #14 (permalink)
I think I ran with that power for about a year ( 7,000 miles).
Got nervous and went forged 402 ala A&A.
Old 12-23-2006, 07:57 PM   #15 (permalink)
Zrod- if 550rwhp can give some measure of longevity, what do you think 575-600rwhp might give you- if tune and fuel are not an issues???? 10K, 20K miles worth of reliable miles??
I plan have the car tuned at Spedd inc, which is know for Conservative tunes on N/A let alone FI... Would adding a Torco add much of a safe net?? I'm to far from 100octane fuel.
Any thoughts on experiance with the LS7 clutch?
Speed Limit? rsherrard The Parking Lot 4 06-26-2007 05:57 PM
LS6 Bottom End Safe Limit jz06man C5 Z06 - Forced Induction & Nitrous 28 10-15-2006 11:11 AM
Is there a time limit GASH The Garage 4 05-04-2006 08:29 AM
Safe to raise the rpm limit with h/c??? Ianz06 C5 Z06 - Pit Road 7 06-13-2003 07:59 AM
Why Limit Colors? AmishVette C5 Z06 - Grandstand 12 02-03-2001 05:35 AM
