Interested in the new Pontiac G8? Visit the Pontiac G8 Forum @ G8forum.com!
» Tire Upgrade Garage
Register Home Forums Gallery Active Topics Search Today's Posts Mark Forums Read
Old 05-07-2008, 08:06 PM   #16 (permalink)
MikesZ06's Avatar
Re: Which Supercharger?? (I used the search)
Originally Posted by chewbakkah View Post
actually i'll listen to mikesz06 cause he's old AND has a z06
mike, what would it cost to have forged internals done, if i do the work myself as far as installing?
oh and by the way your avatar still weirds me out man, i feel like he's judging me every time i read your posts
I will try and respond to both your questions as well as a couple of the points that Z06-Dave brought up.
First, I will assume that Dave is just joking about spending an "extra 3-4 grand" on the internals so that you can run 800-900 rwhp.
Since the compression ratio is so high on the Z06, the first thing you have to do to run high boost is bring that CR down from 11:0 to 8.5-9.0. That means new heads and more likely than not new dished pistons as well. There goes all of your $4000 and then some. Add in the cost of forged crank, upgraded connecting rods & bolts, new rockers, different cam, better bearings, new fuel system, injectors, intake manifold, etc, etc and you're in a whole different financial plain. That's not even considering the fact that to run 8 to 9 hundred rwhp the engine will need to be bored and stroked to at least 402ci. Your clutch that worked just fine at 550 to 600rwhp is now practically worthless so the driveline will need some heavy duty upgrades as well.
As for your question on the cost of forged internals, there are just too many variables to even answer properly. The quality of the parts used (and therefore the cost) goes up with the amount of hp to are trying to achieve (and maintain). Also, the parts that require upgrading are in direct proportion to the amount of hp you are going for.
The comparisons between Buick or any other car for that matter don't really play a role here. Fact is, it would be considerably cheaper to build and maintain an older tricked out Pro Stock car than to build a newer Z06 into a super high hp racing machine. Hell, if Paul was still around, he could tell you just how much it cost just to back-half his Z so that he could reach the eights at the track. Not going into details I can say that it was over $30k....and that's just for the back end.
Old 05-07-2008, 10:12 PM   #17 (permalink)
chewbakkah's Avatar
ok so lets say that i want to run 550 hp at the wheels. and i'd like to do it as safe as possible, what would i be looking at? personally even if i decide to go n/a with almost stock hp i will still get forged parts just for the reliability of them. id rather spend 10k and get stock numbers that will run into the upper 100k mile range than have a car with 700 or 900 hp thats only going to last a while and i'll have to work on all the time. i want the car as a daily driver, something manageable that i'm going to put A LOT of miles on. i just want the thing to last.
forgive my ?'s i'm an information leech so to speak. i like to know as much about a subject as i can when going into something new. (except for the 5 years i spent at college)
chewbakkah is offline   Reply With Quote
Old 05-08-2008, 06:22 AM   #18 (permalink)
MikesZ06's Avatar
Once again, it depends on the car. The C6Z already has forged internals (except for pistons) and should run 100,000 miles N/A or at 550 rwhp very reliably.
Old 05-08-2008, 09:37 AM   #19 (permalink)
REDROCKET02Z06's Avatar
Mike,
Is the C6Z the only C6 with forged internals? Is the LS3 standard cast internals? Just trying to weigh out my best option as far as total $$$ to get to a reliable 600RWHP.
02' Z06/Forged 346ci/Custom Heads/Custom Ground Cam/D-1SC-12psi/Twin Inner Coolers/Stage II Bracket w/ 8 Rib Pulleys/Custom BOV/Fast 90mm Intake/LS2 90mm TB/Bosch 75lb Injectors/LP255L Fuel Pump/Kenn Bell Boost-a-Pump/Melrose Longtubes/Randomflow Exhaust/Hurst Short Throw/Spec.Stage 3 Clutch/Fidanza Alum.Flywheel/Auto Meter Boost-Fuel
Gauges/Dyno Tuned/695RWHP/598RWTQ
REDROCKET02Z06 is offline   Reply With Quote
Old 05-08-2008, 10:53 AM   #20 (permalink)
MikesZ06's Avatar
Originally Posted by REDROCKET02Z06 View Post
Mike,
To be honest, I'm not sure. I assume that the LS3 uses cast internals but I can't swear to it.
Old 05-08-2008, 03:37 PM   #21 (permalink)
I keep hearing the new NOVI is pretty bad azz !
Sleeper C5 is offline   Reply With Quote
Old 05-08-2008, 05:05 PM   #22 (permalink)
Some of the top 1/4 mile times in C5's (Z's and non-Z's) equipped with centri blowers have been turned in by Novi powered cars.
Don Benson is offline   Reply With Quote
Old 05-08-2008, 05:57 PM   #23 (permalink)
Send a message via AIM to Z06-Dave
I do my own work, so figure only the necessary parts.
C6
Z06-Dave is offline   Reply With Quote
Old 05-08-2008, 06:17 PM   #24 (permalink)
MikesZ06's Avatar
I wasn't taking into account labor costs at all.
A good set of ported heads and a top notch crank shaft will run close to $4,000 all by itself.
Old 05-09-2008, 12:33 PM   #25 (permalink)
Wow, I can get the same for my Buick for half that price. How soon I forgot about the Corvette Tax.
Maybe I hold off before I get another Vette...I blew my head gasket last fall, I spent $100 to fix it...Including fluids.
Old 05-09-2008, 01:08 PM   #26 (permalink)
Wow, I can get the same for my Brick for half that price. How soon I forgot about the Corvette Tax.
Fixed this for you.Head gaskets? Of course they're cheaper...you've only got 6 cylinders. I bet clutches are a lot less for those Bricks...oh wait, it's an automatic, so no clutch...it really is your father's Buick.
Old 05-09-2008, 01:12 PM   #27 (permalink)
MikesZ06's Avatar
...and some of them haven't
Sorry guys, kind of a private joke between Don and I.
Don doesn't have a blower but he is close to the people at ECS, which now uses the Paxton Novi set-up after a dispute with Procharger a couple of years ago. Therefore, every time I say the word Procharger, Don likes to chime in
9.87 at 141mph
& 2007 Black C6 Z06
Old 05-09-2008, 01:18 PM   #28 (permalink)
Mike,
Procharger has come a long way in the past few years, and there are many C5/C6 guys running them and making big power and putting down great numbers at the track.
As for ECS and the dispute with Procharger...well, like an old girlfriend told me right before she dumped me, some things just weren't meant to be. You have to move on and make the best of a situation, and I think the guys form ECS have done well with it (and I ended up meeting a marrying a much better woman).
Don
Old 05-09-2008, 01:22 PM   #29 (permalink)
MikesZ06's Avatar
I'm not sure exactly what you mean by the new Novi?
Paxton has had the Novi series out for 15 years I think. A year or 2 ago they came out with a self-lubricating unit (similar to Procharger) that I believe is called the Novi SL. Maybe that is what you are referring to?
For the record, I think the Paxton blowers are very good quality and the difference between their units and Procharger units is probably pretty small.
It all comes down to preference.....
Old 05-09-2008, 01:25 PM   #30 (permalink)
MikesZ06's Avatar
Mike,
Don
Don, I was sorry to see the Procharger and ECS relationship change myself and yes, I would agree that ECS has continued to do well!
Truck Search gtx76 The Garage 1 12-23-2006 09:48 AM
In search of... Madvetter C5 Z06 - Pit Road 5 08-26-2005 03:17 PM
The Search cobraboz C6 Z06 - Pit Road 2 05-26-2005 06:37 PM
In search of?? J.N.F. Member Sales - Parts & Cars 2 01-21-2005 03:38 PM
