Neil, I have the same style bracket (pictured below) and you are going to have a hell of a time putting the belt back on.
[IMG]
[/IMG]
[IMG]
[/IMG]
I had to install the belt on the head unit/bracket first, then install the bracket and feed the belt threw all the accesories. then finally you have to remove the top alternator bolt and push the alt in as much as possible and STRETCH the belt over the alt. pulley.
The first time I tried doing this, even with the tensioner bottomed out, I broke a rib on the belt and it eventually shredded in a thousand miles or so. the second belt I put on didn't rip like the other one and is holding up fine so far.
Maybe you have another way of installing it, I dunno, but this was all I could come up with.
