Old 08-05-2008, 11:46 AM   #1 (permalink)
Send a message via AIM to Stry Send a message via Yahoo to Stry
What the hell has Stry been up to? ....time to spill it !!!
What do you get when you add an LME C5R 427 + 2 @ GT35R's (15 PSI) + Pump Gas (93 Octane) + a NewEraPerformance MAF Tune + a muggy 94* day = ????
....You get a 1000+ WHP - 900+ TQ Street/Strip Car !!!! (Been driving it around town ...Drove it to and from the track [1 hour each way !], made some shakedown runs, drove it home....). Drivability is amazing - awesome tune Mike !!!!
Dyno pull info...
94 degrees, miserable humidity, slicks (same diameter as stock tires, other tires wouldn't hold on the dyno! actually even walked these on the rollers once or twice ), very safe (rich) A/F (future Speed density tune will better control/refine the fuel curve - make the graph a little less "peaky").
So this should be considered a baseline ("proof of concept") run. There's still more there.... Not that it's needed - lol!
PS - These graphs may look a little "funny"... I removed some of the typical graphics you would normally see on the graph because they contained links to the shop and I'm not sure of their vendor status here - so better safe than sorry.
The Highlights:
Plan conceived, parts fabricated, project built and tuned at NewEraPerfomanceParts
An amazing MAF tune by Mike @ NewEra ..... Speed Density coming soon. I can't say enough about Mike and the rest of the crew at NewEra !!!
LME C5R 427 - Custom Weisco Pistons. Lunati 4340 Crank and Pro Billet Rods. Shortblock beautifully machined and assembled by LME - Thanks Brian!
STS twin turbo kit, upgraded GT35R's turbos, dual 38 MM wastegates, (BTW - this system is capable of supplying 20+ PSI to a 427 @ 7000 RPM in it's current configuration... Don't ask !), Meth injection, etc.
ETPerformance 245 (cathedral port) Heads - Thanks Craig @ ETHeads.
Custom (application specific) Turbo cam from Ed Curtis @ FlowtechInduction.
“Out of the box” FAST90 intake, stock L76 Throttlebody, APS Extreme (boost referenced) Fuel System, RC 75 injectors.
RPM "Stage V" M12 Trans, SPEC "P-Trim" twin disk carbon, SFI Bellhousing, Hardened L & R shafts and R spider, Billet pinion support, HD clutch pack, DTE Brace, Aluminum TQ tube bushing, etc.
CCW Drag Pack, Carrara QA1 adjustable shocks, etc.
Like most projects, still plenty of work to do.... I'll keep you posted as the car and I get used to each other at the track. Might be looking for an auto trans conversion very soon !!! It's not caged yet and my "manberries" aren't up to holding the pedal down for more than short bursts at this point, especially on the back half. .....so before you ask - no times yet... MikesZ06 - WE NEED TO TALK !!!!
This project would have been absolutely impossible without the knowledgeable engineering, consulting, fabrication skills, patient support, oversight, encouragement, and generous access to the crew and resources at NewEraPerformanceParts!!!!
VERY SPECIAL THANKS to Brian at LateModelEngines for a great shortblock!! Ed Curtis @ FlowtechInduction and Craig at ETHeads for great consulting, products and OUTSTANDING response and customer support. They provided amazing Heads and Cam. Then expedited custom valve springs and retainers to help me through an initial valve float issue - worked perfect!
Other Pics of the 2008 version of the car:
Here's an earlier graph where we made 1033 by accident!!! (too much boost - 17 PSI . . . you can see we "stepped off" at 6K, it was getting a little crazy on the dyno at that point !!
There's really no magic here, so I will try to answer any questions you might have ...when I can get to the PC. More to come soon.... :cheers
`03 Z06 - LME C5R - GT35-R "Mufflers" - ETP Heads - Ed Curtis (FTI) Cam - Alky Injection, etc. Built and Tuned @ NewEraPerformance - 1002WHP/903WTQ
Stry is offline   Reply With Quote
Old 08-05-2008, 11:59 AM   #2 (permalink)
YumaZ06's Avatar
Re: What the hell has Stry been up to? ....time to spill it !!!
Holy S%&t! Awesome numbers. I hope that you are bringing it to the fest. I can't even imagine what 900 ft lbs of torque is like (probably too much for my heart right now). Wow, I guess that there is a new sheriff in town.
2004 MS/BLK
NCM#31853
Old 08-05-2008, 12:12 PM   #3 (permalink)
Super Moderator
mdickie's Avatar
Send a message via AIM to mdickie Send a message via MSN to mdickie
WOW, that is all I got, just WOW...
Mark
"Civilized until it is time not to be civilized"
mdickie is offline   Reply With Quote
Old 08-05-2008, 12:58 PM   #4 (permalink)
tabratton's Avatar
Send a message via Yahoo to tabratton
Hey just saw this on the other. Congrats again. Man that is some serious power. I hope your coming to the fest. Would love to check it out
TTix 408 Stroker ( Installed and tuned by Dr. Phil)
03'blk z06 mod red int
tabratton is offline   Reply With Quote
Old 08-05-2008, 02:22 PM   #5 (permalink)
WTF over?
Damn, when you decide to go overboard, you don't mess around!
Where's the roll bar? You know you're going to need one. Or is it just a grocery getter?
Sig by the Hillbilly!
jub jub is online now   Reply With Quote
Old 08-05-2008, 02:40 PM   #6 (permalink)
Is that all you got ???
Man, I hope you have that Bad-Boy at the Fest !!!
Pitt
Pit Man is offline   Reply With Quote
Old 08-05-2008, 03:28 PM   #7 (permalink)
NCM Ambassador
Zippy's Avatar
WOW! That's dangerous kinda power!
Anxious to see it at Beech Bend.
Zippy
'08 427 Limited Edition Z06
Old 08-05-2008, 03:50 PM   #8 (permalink)
UVETTYA's Avatar
I can't even imagine that. Holy rat$hit Batman - don't forget your parachute.
Steve
Black '04 Z06
UVETTYA is offline   Reply With Quote
Old 08-05-2008, 04:53 PM   #9 (permalink)
blkZ06's Avatar
holy COW BATMAN!!!
what do ya' have to do to the REST of a car like that to keep it together?
Old 08-05-2008, 06:23 PM   #10 (permalink)
DennyM's Avatar
methinks Garrett would be feeling a bit down on power to the "yellow peril" ...
You coming to the Fest, Stry?
Old 08-05-2008, 06:59 PM   #11 (permalink)
robls6's Avatar
Pretty cool! I remember your car at the fest on 06 and I thought it was badass back then.
2003 MY Z06 - Lunati custom cam, LG headers, Blackwing, McLeod dual disc, RPM stage V trans
409 RWHP
Old 08-05-2008, 08:01 PM   #12 (permalink)
blkZ06's Avatar
uhhh...is your passenger seat free for the MM run?
Old 08-05-2008, 08:32 PM   #13 (permalink)
All I have to say Steve is when you do something, you do it RIGHT! You made some great choices and it sure has paid off! Make sure you get her to the Fest! I got a feeling that there are going to be some national magazine people there wanting to check out all the new builds done by us "Crazy Z06 people" and who knows, we might even get some national exposure. I'll know more about that soon. In the meantime, get the cage done and get her back to the track for some seat time and more "shakedown runs". Can't wait to see some track vids! Great job, my friend!
Jimbo
sig by GR8 White
Old 08-05-2008, 09:10 PM   #14 (permalink)
Very nice. Congrats!
ZO6 AL-X is online now   Reply With Quote
Old 08-06-2008, 07:52 AM   #15 (permalink)
dwjZ06's Avatar
Holy Shit Steve! That thing already sounded like an F16 on a flyby. What's it sound like now? Manberries craked me up Take care, Don
SIG by GR8 WHITE
Happy Birthday Stry!!!!!!!!!!! Jim Lembo The Parking Lot 13 05-21-2008 09:32 PM
Stry's STS Dyno Sheet (... as promised) Stry C5 Z06 - Forced Induction & Nitrous 40 06-17-2007 07:36 PM
Happy Birthday Stry! zoh6prncss The Garage 20 05-19-2006 12:51 PM
STRY--you ever find your vibration? S-TEE Z06Fest / Performance Fest 3 07-29-2005 06:16 AM
Alaska Oil Spill GotZ06? The Garage 13 02-26-2002 07:29 AM
