Old 01-01-2004, 04:31 PM   #1 (permalink)
’05 Corvette Revealed: Smaller, more powerful and sleeker, C6 promises Corvette nirva
’05 Corvette Revealed: Smaller, more powerful and sleeker, C6 promises Corvette nirvana
By KEVIN A. WILSON
(Photos © 2004 Jim Fets)
WE’VE BEEN BEHIND THE WHEEL OF THE ’05 Corvette. Really, sat right there in the bucket and grabbed the thick-rimmed leather-clad steering wheel and made sputtering noises while moving the shifter around, which is more than most visitors to this month’s North American International Auto Show will get to do when they clamp eyes on the thing.
No, we haven’t driven it yet—no one in the car magazine world has—but we’ve finally seen it up close and gotten under its skin. Some will call it evolutionary rather than a leap forward, but there’s no question the ’05 Chevrolet Corvette advances the state of the art. And coming only eight years after the last all-new Corvette, it arrives in time to stay competitive in the marketplace rather than playing catch-up. GM actually expects the sixth-generation C6 to be more competitive than was the C5, widely regarded as a leap forward in Corvette refinement and performance when it arrived in ’97.
2005 CHEVROLET CORVETTE
ON SALE: Fall
BASE PRICE: $45,000 (est.)
POWERTRAIN: 6.0-liter, 400-hp, 400-lb-ft V8; rwd, six-speed manual
CURB WEIGHT: 3245 pounds
0-60 MPH: 4.3 seconds (est.)
The composite body, influenced by both extensive wind-tunnel testing and experience from the C5-R racing program, draws its design inspiration from the landmark ’63 Sting Ray, even though it is the first Corvette since that second-generation (C2) model to run with exposed headlights. We’re told its standard 6.0-liter LS2 Gen IV small-block V8 generates 400 hp and will propel it to an honest, auto- bahn-tested stable 180-mph top speed. It is actually five inches shorter and an inch narrower than the car it replaces, a welcome change in direction for Corvette evolution.
Sleeker, tighter, quicker and more refined—more graceful to use the word chosen by Corvette chief engineer Dave Hill—the car reflects a company more globally aware than the one that last introduced a new Corvette for 1997. It has been tested extensively at the Nürburgring, for instance, and with an eye on European and Japanese competitors every bit as much as on the cross-town rival Dodge Viper.
When it debuts at the Detroit auto show, Chevrolet’s halo car will go to work a full nine months before it goes on sale. Part of its job, after all, is to draw people to Chevrolet, and when show-goers get to the GM stand to see the C6 they’ll find that Corvette is only one of a slew of new products on the floor. It will be joined by the Cobalt, for instance, GM’s latest and perhaps last attempt to build a competitive, small economy car in America. There are eight other new Chevys coming in the next 18 months, and another seven new GM products.
While the principles of C6 engineering are carried over from the C5, nearly every detail has changed. “By weight, more than 85 percent of the car is entirely new,” points out Corvette’s Hill.
Among the few direct carryover parts is the balsa-sandwich floorboard, which still tests out better than exotic composites for its performance in stiffness and noise suppression. It does its work in combination with hydroformed rails (same as on Cadillac XLR) and Hill claims better structural performance thanks to a reinforced windshield frame and a crossbar mounted at the bottom of the dash.
Though the all-independent suspension design with its composite leaf springs is unaltered, every single piece has been changed to refine the performance and to engineer in the longest travel of any sports car in the segment. The suspension cradle and control arms are all-new. Long travel allows the engineers to set the suspension up for both ride-enhancing bump absorption and handling refinement. Thirteen millimeters of suspension travel was added to the front, 20 mm in the rear, and eight degrees of caster was added for better on-center feel.
The base suspension is the FE1. The magnetic ride control is optional, and will again include a two-mode switch, tour and sport, with a greater evident difference between them. Opt for the Z51 performance suspension and you get stiffer springs and dampers, more aggressive tires, brakes and its own gear ratios (shorter through most gears for better acceleration, with a longer fifth for high top speed). A C6 with Z51 option will rival this year’s Z06 for performance, Hill said.
This is so even though the C6 (unlike Z06) rides on third-generation Goodyear run-flat tires, developed to cut road noise and improve ride, as well as provide snow performance, three common customer complaints about the previous tire on the base C5. The wheels are an inch bigger in diameter (18x8.5 front and 19x10 rear), and the tires are 10 mm wider than before at 245/40 and 285/35, Z-rated front and rear respectively. Big wheels make room for big brakes, and if you opt for the Z51 they get bigger still at 13.4 inches diameter front and 13.0 rear. Dual-piston front and single-piston rear calipers with ABS keep things under control.
The Tremec six-speed transaxle still resides out back, but the shifter mechanism has been refined. There is a dual-mass flywheel for smoother, quieter clutch action, the gearshift lever is an inch shorter and angled toward the driver, and the travel for all synchronizers is reduced 10 percent. There’s an all-new linkage, and shift-rail bearings that contribute to a quick, more snick-snick action.
Engineers considered a paddle-shift mechanism, and while it didn’t make it to the 2005 model, you might keep your eyes open for it in future years in either the high-performance Z06 (a 2006 model-year item) or a Corvette-based supercar (the so-called Blue Devil project). The automatic option is GM’s own 4L65 transmission, as before, but it gets a performance algorithm that allows the engine to rev higher before changing gears.
The front mid-engine placement sees the new V8 scoot forward two-thirds of an inch in the chassis, but since the wheelbase is longer, the weight distribution is unchanged. The 6.0-liter Gen IV V8 LS2 will be the biggest base engine in Corvette’s 52-year history when it arrives, and develops 400 hp and 400 lb-ft of torque, with a 6500-rpm redline. It has an aluminum block with iron cylinder liners and alloy heads, and weighs 15.4 pounds less than the 5.7-liter Gen III in today’s car.
The bore is a bit wider at exactly four inches, the compression ratio is up from 10.1 to 10.9, the intake airflow has been improved 30 percent, there’s a new throttle body and a new (composite) intake manifold. Other engine changes include stiffer valve springs and a revised camshaft for more valve lift, as well as a new heavy-duty timing chain, 33 percent lighter exhaust manifold, external knock sensors, drilled main crank bearings, new oil pan and an upgraded water pump. GM claims its C5-R racing program influenced the engine development in power production and durability. One example: The new wingless oil pan better maintains oil pressure in extreme handling maneuvers, even while containing one quart less oil and draining more easily for the home mechanic.
The engine electronics are fully integrated with an active handling system that will allow the driver to slide the car some, even when engaged in what GM calls the most sporting handling-assist mode on the market. Hill promises that it adds up to a more European handling character and that for all the hardware, the real story of the C6 will come when we drive it and find how much the car’s dynamics have improved... we’ll just have to wait and see.
Which leaves us outside, looking at this latest version of America’s sports car. The styling has more edge to it compared to the C5, the fender tops recalling the Sting Ray. The front fenders are slightly higher crowned, so to speak, to evoke Sting Ray. It nods to its heritage without being retro.
“When you stand back and look at the car it must say Corvette,” said C6 designer Tom Peters, who refers to the sharper fender edges as “shoulders.” “It must say ‘American car,’ yes, but an international or global American car. We wanted more crispness and character definition in the shape.”
The exposed headlights and the smiling grille beneath them are the most noticeable differences, creating a different face but one that’s recognizably Corvette. There are fewer panels and cutlines around the headlights and front plate. While the taller fender does intrude on forward visibility slightly, Hill notes that it’s nothing like the obtrusive C3 “shark” car’s fenders, and that the forward sightlines are still much like those in C5.
“Plus, you can look out over the car and not see the air brakes [pop-up headlights] anymore,” he notes. The change to exposed lights was driven by performance, both of the lights themselves, which are projector beams that not only light the road better but stay aligned better, and of the car overall. Other sports car makers (think Acura’s NSX) have abandoned hideaway lights for similar reasons.
“The exposed lights are really inspired from the C5-R race car,” noted GM vice chairman Bob Lutz. “They have genuine racing heritage.”
Designer Peters says the car has a more serious, straightforward look to it without the hidden lights. Some observers will see Viper, others will note the light shape and think of Mitsubishi’s 3000GT. We have a few months to get used to it before the car goes on sale in the fall, anyway.
There are integrated door handles in the back edge of the door, as on XLR, and the B-pillars slant rearward instead of forward as on the C5. The windshield is slightly more upright; the idea here was to cut wind buffeting when the top is out. The top is larger than before, only a bit heavier, and stows horizontally, leaving a better-shaped luggage space beneath.
The body is five inches shorter overall, two inches shaved from the front and
three from the back, so overall length is within millimeters of the Porsche 911. At the rear axle line, the car is one inch narrower and this helps the tail look less massive than the C5’s. The wheelbase is 1.25 inches longer, the height is the same as before and the weight is the same (since the car is engineered to fit within the EPA weight class).
The coefficient of drag is improved to 0.28 from 0.29 (C5). The car isn’t necessarily a “downforce car” like the race car, but has benefited from the C5-R experience. GM feels it can’t put much downforce in the car without having a negative impact on fuel economy. However, it moves in that direction by reducing lift. Hill and Peters had no numbers to quote on anti-lift coefficients, but point to the top speed of 180 mph, up from 171 (Z06) and 175 (standard car). They said they wanted the 180 mph to feel stable and confident, not as if the car is at or close to its ultimate limits.
Hill said GM has done more dynamic testing than ever focused on this (autobahn, Nürburgring), confirming not only that the C6 can get to 180, but that the car behaves as intended at those speeds.
Several things combine to achieve this according to GM: The CHMSL (built into the top of the rear fascia) acts as a bit of a spoiler, the back glass area, fenders and rear quarter areas are contoured to minimize lift. The car’s widest point is the rear axle area, narrowing at the rearward-most points, for both styling and aero.
The underbody and rear fascia help air exit from under the car in a more controlled way, Peters said. It was modeled after the C5-R in terms of air-flow, including the use of the close-out panel called a diffuser that houses the exhaust tips and backup lights. The C5 has no such panel, the exhaust tips kind of float underneath a rear fascia that doesn’t manage the underbody airflow as does the race car. The tail looks tidier, and the panel also fits better where it meets the rear quarter-panel.
GM used super-computers to do the aero modeling, meaning running dozens or hundreds of dozens of tests at the same time instead of one at a time, reaching far more specific and precise conclusions. Still, the biggest wins came the old-fashioned way, both for appearance and aero performance: hand sculpting of the exterior in GM design studios, “sweetening” the computer-drafted shape, and more than 400 hours of wind-tunnel time, more than GM has ever done on any car.
Inside, GM is promising dramatic improvements in material quality, though we couldn’t judge that on the prototypes we were shown: The materials were faked-up for photography purposes, not yet in their final production form. What we could see, clearly, was that there are fewer pieces, so fewer seams and gaps. Hill said every concern that C5 customers have expressed has been addressed inside. Despite the overall shorter layout, the cabin space is the same as in this year’s car, both in passenger accommodation and cargo volume.
Anodized aluminum accents, two “real-world” cupholders in the console, and optional DVD navigation system in the center stack are notable additions. The reconfigurable, optional head-up display offers two modes: street and track. In street mode, you can have, say, the speedometer and turn indicators displayed. Track mode offers a big tachometer and engine gauges, plus a real-time lateral accelerometer (it holds onto a peak reading long enough that you can look at it on the following straight, rather than trying to watch it mid-turn).
Only the coupe will debut in Detroit. The convertible will be shown later in the year, and the Z06 will be a 2006 model-year item. Hill said it will differ more from the C6 on which it is based than today’s Z06 is from the C5, and talk of 500 hp is widespread. Thanks to the existence of the Cadillac XLR for the luxury touring car crowd, Corvette engineers will be free to concentrate on the performance side of the equation. It’s looking like an exciting time for Corvette fans.
photos too..: http://www.autoweek.com/cat_content...._code=03176519
Happy holidays!
Corvette Owner's Club of Houston - Sugar Land Corvette Show - April 9 blazeone Midwest 4 04-09-2005 05:58 AM
Corvette Owner's Club of Houston - Sugar Land Corvette Show - April 9 blazeone Southwest 0 03-07-2005 03:05 PM
C6 Corvette Revealed Today! Zippy C6 Z06 - Grandstand 22 01-01-2004 08:07 AM
2005 Corvette Revealed! CDHough C5 Z06 - Grandstand 88 07-11-2002 10:04 PM
"The American eagle is sleek, fast and powerful, so is the American-made Corvette." NVGRWUP The Garage (non Vette related) 0 07-04-2002 10:01 AM
» Latest Auto News
Lexus Returning to Nurburgring 24 With New LFA Race Car
For the third straight year in a row Lexus will compete at the
Ford Mustang GT Gets Best-In-Class 17-MPG City, 26-MPG Highway
Not only does Ford’s new 5.0-liter V8 for the 2011 Mustang GT
Hyundai Customers Most Loyal to Their Brand Says Kelley Blue Book
According to the most recent numbers released by Kelley Blue Book,
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
2010 Acura RDX SH-AWD
Acura's RDX is the only luxury crossover that delivers on its
2010 Lotus 2-Eleven Review
With the 2-Eleven, Lotus has built a track day superhero
