Re: 08 Z Cats bad already?!!
HI there,
The P0420 is for lack of oxidation capability.
Either the converter is coated and cant oxidize correctly, in which case you should be fine.
OR the converter broke apart and could create a restriction which could lead to power loss.
Either way, for the most part, you should be ok to drive but if you notice a loss of power and lower fuel mileage, chances are your restriction presented itself.
Allthebest, c4c5
