Old 08-11-2007, 05:58 AM   #1 (permalink)
Any Fix Yet for Shifter Rattle?
My '07 had an August '06 build and I have been dealing with the shifter rattle during acceleration for about a year now. Is their any SB or fix yet????
Thanks on advance.
Z06 and M5 is offline   Reply With Quote
Old 08-13-2007, 10:47 PM   #2 (permalink)
Re: Any Fix Yet for Shifter Rattle?
Don't know about '07's but they just released a fix for the '06's. Got mine done today.
spike is offline   Reply With Quote
Old 08-14-2007, 04:03 AM   #3 (permalink)
Sooooo, What's the fix and the TSB number?
Jack
The Godfather is offline   Reply With Quote
Old 08-14-2007, 06:14 AM   #4 (permalink)
MSiska's Avatar
Same as Jack...very interested! Give us the info please!
Old 08-15-2007, 08:26 AM   #5 (permalink)
The service order only states that they replaced the Shifter Control Assembly, part number 25823571. I got a call from both the dealer and the Chevy customer service center on the same day last week saying they finally had a fix. That was about a week after I called the customer service center and complained long and loud. Coincidence?
Old 08-17-2007, 09:31 AM   #6 (permalink)
I think this is it.
#PIC4355A - (08/13/2007)
KINGPIN is offline   Reply With Quote
Old 09-13-2007, 10:23 PM   #7 (permalink)
FIXED!!!! The part was installed a few weeks ago!
Z06 and M5
Old 09-14-2007, 09:26 AM   #8 (permalink)
I may regret saying this, but every Corvette I have owned for the last 42 years had a shifter that rattled.
Now my new 2007 Z06 does not rattle. Am I lucky or what?
Rauchy is offline   Reply With Quote
Old 09-14-2007, 07:25 PM   #9 (permalink)
Mark_02_Z06's Avatar
My 2002 Z06 shifter has never rattled. Anyone with a C5 have a rattley shifter?
Mark_02_Z06 is offline   Reply With Quote
Old 09-22-2007, 09:50 PM   #10 (permalink)
Just wait til you have the car sit overnight somewhere at 40 degrees F. I will most assuredly rattle. I have not heard mine rattle [and it rattles bad] since March when overnight temps were dipping into the upper 30s/lower 40s. They were supposed to have a fix for the 07s 6 months ago.
Doc E.
Dr.Electron is offline   Reply With Quote
Old 09-23-2007, 02:42 AM   #11 (permalink)
Virtually all '06 and '07 shifters will inevitably rattle at some point. However, it often takes a few thousand miles before the problem manifests itself. If yours is not making the noise yet, it likely will in time.
The rattle/buzz is a result of vibrations within the transmission being transmitted and made audible via the shifter. The actual cause is a hard plastic bushing inside the shifter shaft where it flares out. The only way to examine this is to cut the shifter open. The fix was a redesign of this bushing material which is now a hard rubber compound. The purpose of this bushing material is to absorb hard shifts. When cold the hard bushing would vibrate against the shaft. After it became warm enough it would exapand and the clearance would diminish allong with the noise.
This is directly per GM engineering including 'autopsy photos' of a shifter that show what I'm describing.
I had my '07 shifter replaced per the TSB and part number above on September 6th. The procedure took about an hour and was covered under warranty, no questions asked.
Old 09-23-2007, 05:32 AM   #12 (permalink)
Well that sucks. How do other cars manage to make a shifter that doesn't rattle? It is the little stuff like that that made me think my 90 C4 was going to be my last Corvette.
If the engineers can't figure out how to eliminate a shifter rattle, what are they doing playing with more complex stuff like engines?
Gee whiz.
Old 09-23-2007, 07:02 AM   #13 (permalink)
GRSZ06's Avatar
Send a message via Yahoo to GRSZ06
Not only shifter rattle, anyone having trouble keeping the ashtray door closed??
2006 C6 Z06
GRSZ06 is offline   Reply With Quote
Old 09-23-2007, 12:38 PM   #14 (permalink)
There have been many reports of the ashtray door not staying shut. The warranty fix appears to be replacement of the following two items:
p/n 10324612 Latch
p/n 10324613 Dampener
Old 09-24-2007, 07:01 AM   #15 (permalink)
I had the shifter ratter TSB accomplished with the new shifter and my rattle is now worse than ever.. There's several other that have experienced this too.
07 Z06, Atomic Orange ... mods on the way.
LSC 427 Shelby Cobra, 427 aluminum side oiler (482"), Tremec TKO, coil overs & a Ford 9"..
04 custom cycle, 100ci Revtech, 6sp tranny, custom paint & chrome.
undy is offline   Reply With Quote
Help!!! Visible rattle and noise coming from shifter. Maybe the tranny. brianschenck C5 Z06 - Pit Road 7 07-04-2006 08:47 PM
Stock shifter rattle question. Clay C5 Z06 - Pit Road 4 04-18-2004 09:34 PM
Breathless shifter - any way to eliminate the rattle? Andi C5 Z06 - Pit Road 18 08-11-2003 04:52 PM
Hurst Shifter Installed! Does it rattle???? Hye06 C5 Z06 - Pit Road 4 10-24-2002 12:17 AM
Has anyone found a fix for the EXHAUST RATTLE? BIG LAW MAN C5 Z06 - Pit Road 56 06-04-2002 11:36 AM
