Old 10-16-2007, 11:07 PM   #1 (permalink)
Any update on tires for the stock Z wheels?
The run flats on my Z06 are due to be replaced soon, and there's no a lot of traction if the temperature is less than 85 degrees outside. When I first got the car it was summer time so I'm not sure if it was weather or new tires or both that were stickier when I first got the car.
Hoosier racing slicks would stick but I want tires that will last more than a month.
jeffareid is offline   Reply With Quote
Old 10-17-2007, 10:25 AM   #2 (permalink)
Re: Any update on tires for the stock Z wheels?
tirerack.com is probably one of the best sources of new tire availability info...good luck.
ZIZZLIN is offline   Reply With Quote
Old 10-22-2007, 12:08 PM   #3 (permalink)
catbert's Avatar
The replacement tire choices are dammmm slim.
2007 RFE #330
catbert is offline   Reply With Quote
Old 10-24-2007, 01:13 PM   #4 (permalink)
PS2s: 275 and 345, f/r.
Old 10-24-2007, 01:46 PM   #5 (permalink)
I'm in the same boat as you. I did some research, and basically there are 2 types: runflats or non-runflats. If you want to stay with runflats, there are 2 choices: OEM Goodyears (excellent choice by the way), or Michelin ZP. If you want more traction than the runflats offer, then you're looking at Michelin Pilot Sport, Michelin Pilot Sport 2, Michelin Pilot Sport Cup (80 treadwear, racelike rubber), or the Nitto Invos.
If you don't mind the risk of getting a flat tire, and are after maximun traction, the Cups are the way to go.
Good luck,
Black/Black C6 Z06, 1LZ Navigation: Thanks to Jason Walter at Ross Downing Chevrolet!!!
Rapid Transit is offline   Reply With Quote
F/S Stock 02 Wheels/exhaust/tires prvettguy Member Sales - Parts & Cars 0 08-20-2006 12:37 PM
Stock 02 wheels with tires MY02Z Member Sales - Parts & Cars 3 01-27-2005 05:40 AM
FS: Stock Z06 Wheels AND Tires ForceFedZ06 Member Sales - Parts & Cars 1 01-19-2005 09:45 AM
FS: 02 Z06 Stock Wheels/Tires 22349(b) CVC Member Sales - Parts & Cars 3 12-09-2004 12:01 AM
Stock 02 Wheels/Tires GMRACIN Member Sales - Parts & Cars 8 01-15-2004 04:53 PM
