Average maintenance cost for c6 z06??? - Z06Vette.com - Corvette Z06 Forum
Old 01-22-2013, 10:09 AM   #1 (permalink)
So I'm new to this site and I'm in the market for an 06-07 z06 it was a done deal until a buddy told me there ridiculously expensive to maintain. Just looking for some advice on what some current owners are paying to keep there vettes on the road. I'm just a lowly E-5 in the military so I need to know if I can afford this thing. Thanks
KBro-Slice is offline   Reply With Quote
Old 01-22-2013, 11:12 AM   #2 (permalink)
Z06 Tech Advisor
racingvette's Avatar
Re: Average maintenance cost for c6 z06???
Your buddy really does not have any experience in owning a Corvette, they are built tough and proof is how many C4s are still on the road as daily drivers with over 120,000 miles on them
Maintenance is cheap, normal oil/fluid changes less then maybe $100 a year at most, if driving less could be less then $50 a year.
Fluids in transmission, rear end, power steering, etc need seldom replacement.
There is no costly special requirements for fluid changes which non American cars do have.
Might use some gas/fuel injector and de-carb cleaner, cheap any part store.
Other then that and if doing some type of track events then look at changing brake pads and of course tire replacements which all cars would require.
Mike M - 2001 / 2008 Z06s
Old 01-22-2013, 01:31 PM   #3 (permalink)
itsaz's Avatar
I think you'll find that tires will be your biggest expense. Average tire life on a C6Z seldom exceeds 20,000 miles. Discount Tire just happens to be a supporting vendor of Z06Vette.com. You can search their site for tires that fit the Z and your budget.
itsaz is offline   Reply With Quote
Old 01-22-2013, 01:37 PM   #4 (permalink)
MiamiCowboy's Avatar
Manufactures have done a great deal to reduce the maintenance cost of cars over the last decade. Beyond routine oil changes you have very little to worry about. On the Corvette you should change oil at least 1 time a year if you do not exceed the mileage recommendations. Dry sump will take more oil but it is not that big a deal. The coolant goes for 5 years or 100,000 miles, there are no lubrication points on the suspension or drive train and other fluids rarely if ever require anything more than a routine check. You will need to cycle the clutch fluid periodically but that is very easy and very inexpensive to do. Air cleaner is nothing terrible to handle as well. Tire wear will be dependent on how hard to drive the car but should go at least 15,000 miles on the soft compound.
I am on my second Z06 and is one of the most reasonable cars to maintain. Keep in mind that it is a high performance vehicle and should command above average attention by the owner but not above average expense. Your friend is really clueless. Go for it.
MiamiCowboy is offline   Reply With Quote
Old 01-22-2013, 02:48 PM   #5 (permalink)
KBro-Slice, your "buddy" is probably jealous and couldn't stand the thought of you having a corvette! As said above, it is not a "needy" car in terms of maintenance.
Old 01-22-2013, 04:28 PM   #6 (permalink)
PerforminNorman's Avatar
How many Corvettes does your buddy own or has he owned? Is he a credible source?
Old 01-22-2013, 04:29 PM   #7 (permalink)
K-bro,
I echo what these other guys have said. I have owned two vette's and maintenance costs have been virtually non-existent. Tires are the most expensive aspect of owning a vette.
2007 Z06- Lingenfelter 660 package (569 RWHP, 500 RWTQ)
2012 Fiat 500 ABARTH
2008 Ducati 1098 and 2007 Kawasaki ZX-6R
2006 Honda Civic Si
DucZ06 is offline   Reply With Quote
Old 01-22-2013, 06:32 PM   #8 (permalink)
Thanks for all the input. And as far as I know he hasn't owned a corvette has a 350z. He's a fairly credible source he knows his cars just wanted to fact check. Sounds like this is a win win, I'm definitely in the market for one.
Old 01-23-2013, 08:13 AM   #9 (permalink)
I agree with the low maintenance costs. I need to replace the battery in my C6Z every 2-2.5 years due to lack of use in the winter and I don't keep it on a charger. Other than that all is great.
4vettezo6 is offline   Reply With Quote
Old 01-23-2013, 05:58 PM   #10 (permalink)
zteve06's Avatar
I have read multiple complaints in my corvette mags in letters to the editor, that many people were only getting 2-5k miles on their rears. I don't have a c6z, sigh, but I've had no problems with mileage myself on the c5z I own. The c6z, now lets be honest, is riddled with problems, and if you have no warranty, you might not be able to afford to drive one. I have seen some on here complaining of problems that should have been covered by the warranty, but weren't.
But that happens. My wife had a 1997 VW Jetta Glx that was 6 months old, and caught fire in the engine bay, from a short, and they refused the warranty.
But, I suggest you get one with a warranty. Apparently, these c6z owners are a little biased. And who could blame them...but, this site will save you money with its info and help and Dyi's. (do it yourself articles) A good time to buy one would be after the c7 has been out for a while. They probably won't dip under 30k for a while, but you might be able to get a beat up, hi mileage, flood or theft recovery c5z for 15k.
Zteve06
blk 02 z06
Austin,Tx
zteve06 is offline   Reply With Quote
Old 01-23-2013, 06:27 PM   #11 (permalink)
itsaz's Avatar
"riddled with problems"???
Old 01-23-2013, 07:35 PM   #12 (permalink)
Have owned 2 C5s and 2 C6s and haven't had many problems with any of them. There has been a couple of things but nothing expensive or anything that cost me much at all.
Old 01-23-2013, 07:46 PM   #13 (permalink)
wtxz10's Avatar
Zteve06
blk 02 z06
Austin,Tx
What? My 06 just rolled over 30k and I've done nothing to it other than tires and fluid changes. The sky is not falling with the C6 Z. My 2cents.
1969 Z10 Camaro Pace Coupe
1979 RX7
2004 RX8
2006 Z06 Lemans Blue
wtxz10 is offline   Reply With Quote
Old 01-23-2013, 08:28 PM   #14 (permalink)
zteve06's Avatar
By riddled, I mean, the c6, in general, I'm not aware of the c6z having more problems than the coupe, except for the fuel system. But I am only reporting my observations. I think anyone could spend some time searching for its problems here, or elsewhere on the web. But, his question was about maintenance, not reliability. My car uses 40 percent of its viscosity after a couple hundred hard miles, or a trip to the dragstrip. So, obviously, maintenance costs vary with use.
But I should think that anyone who owns a corvette, probably has a little money for such things as frequent oil changes or new tires. This guy might just be slamming the car, who knows, we'll see if he buys one.
And a funny thing about cars-one model is a lemon, and another is perfect, though they be the same. So you never know. Sorry if I offended anyone. I love the ls7, but not so much the car.
Zteve06
Blk 02 z06 (purpose built)
Austin,Tx
Old 01-23-2013, 09:44 PM   #15 (permalink)
Z06 Tech Advisor
Zteve06
blk 02 z06
Austin,Tx
Your problem is reading and taking faith in what car rags say when in fact
places like JD power backs up what most Corvette owners know is if the car is treated right and no bogus mods used then
C6
Scorecard
Overall: 9.0
Critics' Rating: 9.3
Performance: 8.9
Exterior: 9.5
Interior: 7.2
Reliability: 9.6
Average cost to track C6Z emccalment C6 Z06 - Grandstand 29 01-03-2013 02:46 PM
Window Tint cost average? FalconJack C5 Z06 - Pit Road 9 07-06-2007 11:07 AM
Are you just average? GroundFighter C5 Z06 - Tuning & Electronics 6 12-11-2002 09:29 AM
What is the average age here? Accord The Garage (non Vette related) 110 11-17-2002 10:45 AM
The average man? Z06phile The Garage (non Vette related) 11 08-18-2002 07:16 PM
» Insurance
» Latest Auto News
2014 BMW M5 Officially Revealed with Minor Updates
As expected, BMW has unveiled its 2014 M5 sports sedan, giving it a
Watch Australian V8 Supercars at Circuit of the Americas Live Streaming Online
This weekend, the Australian V8 Supercar Series heads to America for
Commute, Toy or Destroy VW Corrado vs. Honda CRX vs. Ford Mustang
We are back with this week’s instalment of AutoGuide’s newest,
» New Car Reviews
2014 Lexus IS 250 Review
From staid to sultry
2013 Buick Enclave Review
Sport compact sedan 2.0
» Featured Product
