Old 07-01-2008, 12:16 PM   #1 (permalink)
Beehive... very good mod!
This is the Beehive from Halltech, keep the cold air in the Killerbee area for more HP, also looks very good... dyno # soon
***edited***
you can buy it at Halltech website.
Silver C6 Z06
Z Power is offline   Reply With Quote
Old 07-01-2008, 12:55 PM   #2 (permalink)
Re: Beehive... very good mod!
Hmmm...do you have the hole cut in the radiator shroud?
02 MY Z06 440RWHP/402RWTQ - Sold
08 BLK/BLK Z06 - Bone Stock
Old 07-01-2008, 01:27 PM   #3 (permalink)
Z06 Maniac!!
Lawdogg's Avatar
Installed my Beehive last week. No shroud cutting required. Entire install is reversable to stock. Some choose to cut shroud to pack in more air. I did not cut the shroud.
'07 Z06 Lemans Blue
Old 07-01-2008, 01:53 PM   #4 (permalink)
DaOtherOne's Avatar
Did you notice in seat in the pants improvement after you did the install?
DaOtherOne is offline   Reply With Quote
Old 07-01-2008, 05:31 PM   #5 (permalink)
I decide not to...
Old 07-01-2008, 09:50 PM   #6 (permalink)
Looks pretty good. Do you also have a tune done?
Old 07-02-2008, 08:54 AM   #7 (permalink)
Yep, I tune it myself, put 476 whp with Killerbee and tune only... I have to go to the Dyno again, Jim give me some pointers so hopefully the car will put a little more HP on the rolls
Old 07-02-2008, 09:36 AM   #8 (permalink)
I just bought the V2 for EFIlive so I can tune mine. I have the Halltech Killerbee, headers and a 160 stat. Gas mileage at the moment sucks really bad so I know a tune is in order.
Can you give a brief rundown on the tables you tweek? I do have experience tuning my C5 but I understand the E38 PCM is a whole new ballgame.
Old 07-02-2008, 10:29 AM   #9 (permalink)
I have LS2edit, If your MPG sucks right now have a look of your A/F, you have tune it to 12.5 to 12.9, this can be if you lean it a little bit with the PE/RPM and combine it with more agressive timing... is a good chance you see better whp and mpg with that...
Anyone running Comp beehive springs? jub jub C5 Z06 - Pit Road 5 12-03-2006 02:39 PM
found a Z06 for good deal. Too good to be true? BoysNightOut C5 Z06 - Grandstand 16 05-23-2005 09:12 PM
Good Air = Good Trap Speeds Ranger Racing 9 04-04-2004 07:21 AM
Are there any good cheep rims that would be good for etstreets on a 02Z06 enderz06 Racing 5 07-17-2003 04:25 PM
Good track rotors...eradi's any good?? Silver Bullet Racing 0 02-17-2002 03:44 PM
