Not perfect, but pretty close. Good enough, I think, if you're going to engrave it into a cabinet face.
I can't promise my DXF conversion will work for you, though it looked right when I opened it in Illustrator. So, there's an EPS as well, which hopefully you'll be able to convert yourself if the DXF doesn't work.
DXF Version
EPS Version
UPDATE: Well, that's really weird. My Hosting service is GoDaddy. Apparently, whatever they're running as a Web Server doesn't like "DXF". The file was on my site, but it refused to be served up by HTTP (FTP could see it fine, though). I tried a bunch of stuff and finally just renamed the DXF to TXT (which is really all a DXF is, anyway). Clicking the DXF link now ought to pop up a text file which you can then save locally as a DXF. (I'd also note that the EPS is saved on my site as EPS, but when you click the link I provided, it wants to be saved as just plain "PS". Weird).
