Old 06-29-2006, 07:16 PM   #1 (permalink)
C6Z vs C5Z handling
When driving my C5Z today it occurred to me that what I really want from the C6Z is better handling. Not that what I've got is not good, and not that the extra power in the C6Z isn't nice, but the real goal for me is improved handling. Hell, I'd even gladly trade all the extra power in the C6Z for handling improvements if I had to.
I'm sure the C6Z has a bit higher static cornering limits, but there's one aspect in particular I'm curious about. There might be some technical name for this, but I don't know it, so will have to describe it the best I can. Consider hard cornering, maybe in the 0.8-9G range. If you have the luxury of "easing into" the straight afterword, everything is fine, and the car transitions smoothly between the hard cornering and the straight. But if for whatever reason you have to straighten out suddenly, in the C5Z you tend to get some body "bounce" or oscillations, for perhaps 0.5 to 1 sec, which can be a little disconcerting.
It's hard to describe the phenomenon exactly, but maybe y'all know what I'm talking about. The C5Z does fairly well, compared to most cars, but I want better. Is this aspect improved in the C6Z?
novetteyet is offline   Reply With Quote
Old 06-29-2006, 08:03 PM   #2 (permalink)
great post.
looking forward to the replies.
also what can be done to the c5 to correct this
wrecked'em is offline   Reply With Quote
Old 06-29-2006, 08:14 PM   #3 (permalink)
IMHO, the C5Z is already pretty darned good - probably among the best in the price class. Although I haven't driven one to directly compare, I suspect the Lotus Elise does better on this front. I hope Chevy moves in that direction...
Old 06-30-2006, 03:12 PM   #4 (permalink)
I think the phenomenon you described is common in C5's and C6's. I think Car & Driver discovered it as well and as a result was terrified of the C6Z's handling in this article:
http://www.caranddriver.com/comparis...vette-z06.html
'03 QS/BLK, lightly modded...
Hurst shifter, CAGS defeat, 8" antenna, A&A frame savers, gunmetal gray tint, lowered on stock bolts, C5 sport seats.
wh921 is offline   Reply With Quote
Old 06-30-2006, 08:09 PM   #5 (permalink)
RC45's Avatar
Hmmm.. I am able to generate 1G+ cornering loads with my car and just thought the behaviour you describe, which is a slightly tail happy raunchy oversteer on demand, is the way it is.
I kind of like it.
Old 06-30-2006, 08:36 PM   #6 (permalink)
I see that you have an '02 as well.
Do you feel your car 'float' or 'hover'? Is that what you're experiencing when transitioning?
If so, there an easy, relatively inexpensive fix--'04 OEM Sachs shocks.
They're the real deal in squelching that behavior
George B.
* '08 JSB Z06 11.4 @ 125 on EMTs, 481/454 SAE #s--some bolt-ons...
* '90 ZR-1 SGC built 368ci 'Factory Black Motor' (11.0 @ 130.2 & 11.2 @ 132.4) w/ the 368 (408ci Stroker coming!)--sprayed 120 shot.. 448 RWHP on motor, 560+ RWHP on the spray (SAE #'s)
Old 06-30-2006, 09:16 PM   #7 (permalink)
Hmm, yeah, I suppose you could describe it as "float". The body seems to move around a bit with respect to the wheels. It damps out pretty fast, but it's annoying and makes quick transitions less predictable. I'm after more "scalpel-like" handling
Thanks for the tip on the 04 shocks! I shall investigate this... Doesn't sound too expensive... Does it require an alignment afterwords?
Old 06-30-2006, 09:34 PM   #8 (permalink)
No realignment needed. You'll be very pleased w/ how the shocks excorcise the disconnected floaty feeling when transitioning.
There's a small course we run & one particular corner would upset the car w/ the stock shocks.
After I replaced the shocks, then back @ the same corner--problem solved
Abt $320 for the set--$$ well spent...
Old 06-30-2006, 10:10 PM   #9 (permalink)
Awesome - sounds like just what I want. thanks!
transmission c5z and c6z??? LMS2707 C6 Z06 - Pit Road 3 12-04-2006 12:23 AM
H/C c5Z vs. c6Z andrew675tt C5 Z06 - Pit Road 11 11-17-2006 05:26 AM
C5z / C6z colorado z06 C6 Z06 - Grandstand 27 10-05-2006 10:50 AM
Which shocks for my '01... '04 C5Z or '06 C6Z? Z06phile C5 Z06 - Pit Road 12 10-11-2005 08:48 AM
C6Z vs C5Z Weight Sabot C6 Z06 - Pit Road 12 03-09-2005 09:05 AM
