Old 07-15-2008, 05:40 AM   #1 (permalink)
Zoeaux6's Avatar
Darnedest thing. Advice for filing slight scratches in paint
Unbelieveably, two or more racoons had a party on my 08Z in my garage two nights ago. I haven't figured out where they are or how they got in there, but they found some dogfood and had a huge party pooping all over my hood and then walking through it. I tried to be gentle removing it, but I scratched the clearcoat. It was like tar. How do I fill in the scratches without removing anymore clearcoat?
Crazy stuff, and I didn't think I needed a car cover.
And, yes, this is probably one of those stories you keep to yourself, but I would rather get some advice on a good solution.
Zoeaux6 is offline   Reply With Quote
Old 07-15-2008, 06:49 AM   #2 (permalink)
PerforminNorman's Avatar
Re: Darnedest thing. Advice for filing slight scratches in paint
I'm afraid you are probably going to have to do some rotary buffing. Filling in scratches is only a band aid and the scratches will reappear.
If the scratches are deep enough, you might have someone wet sand a bit. I hope it isn't that deep. Doesn't sound like it is.
Come to the Z06 Fest!
Performin' Norman
Old 07-15-2008, 07:26 AM   #3 (permalink)
oooooh, man. thats a bummer.
Comprehensive insurance, $250 deductible, repaint. ???
Just a moment son, Dewey Cox has to think about his entire life before he plays
Eric_Rav is offline   Reply With Quote
Old 07-15-2008, 07:43 AM   #4 (permalink)
wvphoto's Avatar
i have used the mcguiers scratch remover on small areas..
works pretty amazing..
little black squeeze tube..
***i need a life**********
FEAR THE MIATA
Old 07-15-2008, 12:33 PM   #5 (permalink)
I to have used scratch x with good results.IF you can feel the scratch with your fingernail,well i don't think scratch x will help.time to take your car to a good detailer or bodyshop and have them wheel it out.
al
big al is offline   Reply With Quote
Old 07-15-2008, 05:01 PM   #6 (permalink)
PerformanNorman is right if they are deep scratches. You said slight. If they are slight from pushing dirt into the clearcoat while rubbing you may get lucky. I did a similar thing when someone told me to use a dryer sheet to remove bugs because it doesn't strip your wax. well the bug parts scratched the clear. I used a porter cable w/ scratch and swirl remover from Zaino think it was called Fusion. It diminishes as it's used. Use an Orange lake country pad and use # 4 speed on the P/C. Move slow back and forth and up and down and let the Fusion work w/ moderate pressure. Do this until the fusion dries. Then buff off w/ micro fiber and inspect. I had to repeat a couple of times on some spots. Then I did it again w/ a white pad which is softer. Rotary buffing is for someone who has experience. If you grab an edge or stay in a spot 1 second too long your screwed! Ask me how I know. Then follow w/ glaze and wax ,whatever you use.
MY paint match ..need advice extents The Garage 13 11-14-2005 08:57 AM
tax question, changing filing status, slow99 The Garage 15 04-19-2005 01:38 PM
Paint Scratches Porsche Killer C5 Z06 - Pit Road 7 03-05-2003 05:38 PM
Need your help/advice - Paint shop jerking me around... Whiplash C5 Z06 - Pit Road 24 01-15-2003 04:59 PM
Something funny with my paint. I need advice. CRUZMISL C5 Z06 - Pit Road 10 03-06-2002 06:27 AM
