Differential fluid change, Dexron LS Gear Oil done
Was done today. Axle Chatter/Clanking rear end noise GONE. Under warranty Bulletin ID# dated 01/09/2008, #2048181. Drain/flushed and add just under 3 quarts of GM Dexron LS Gear Oil P/N 88861624. No additives.
Picked up the C6 Z06 and did 8-10 figure 8's in the dealerships back parking lot. This got my posi unit lubricated well. Drove home approx. 20 miles. No rear end noises now. Turns no clanking or thrashing sounds either.
Shifting in traffic from 1st to 2nd gear NO more pounding like pinion bashing. No clanking in the rear end at all. Tranny is quiet.
So for 20 miles I'm happy. If this new fluid fails me I'll post but so far it's done well .
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
