Finaly, got my EBCM fixed! - Z06Vette.com - Corvette Z06 Forum
Old 12-06-2012, 12:02 PM   #1 (permalink)
I bought a new unit from Chevrolet. With my discount it was $850.00 with tax. Installed it myself which was a pain. I had to disconnect the brake lines so I could remove the entire unit. It was either that or bend the brake lines some to get the needed clearance. Took it to the dealer this morning and they flashed it for $125.00. I didn't get a break on this because of their TIS fees, which are quite substantial.
So, no more lights or codes. I will have to bleed the air from the ABS module but I'll do that at a later date with the help of a friend with a Tech 2.
Old 12-06-2012, 12:29 PM   #2 (permalink)
Jim Lembo's Avatar
Re: Finaly, got my EBCM fixed!
Glad you got it fixed Jub, but I still don't understand why GM didn't warranty it? I would have raised bloody hell about it!
sig by GR8 White
Old 12-06-2012, 04:24 PM   #3 (permalink)
XFordGuy's Avatar
That sucks, Jub. I didn't realize that C6 EBCM prices were that much higher than C5.
I know I was a happy guy when I replaced mine and everything worked again. I hate buying expensive parts that don't fix the problem, but I've done it anyway.
Old 12-06-2012, 06:06 PM   #4 (permalink)
I know Jim. Warranty is out and the 100k drivetrain warranty doesn't cover that. I'm sort of glad I did it myself. I took my time and put everything back the way I found it. The techs at the dealer are rushed and I don't think they really care if everything goes back together the way they found it. I'm sure there are many good techs out there like Paul, C4C5specialist! I would let him work on my car. I just don't know who the others are.
I was somewhat worried that it might not work especially after spending that amount of money. My wife thinks I'm crazy for not taking it to the dealer. Women!
Did you have to have yours programmed?
Old 12-07-2012, 06:19 AM   #5 (permalink)
2MchFun's Avatar
Glad you got it squared away John. That was an expensive computer
Old 12-07-2012, 11:24 AM   #6 (permalink)
Just trying to help out the economy.
Old 12-07-2012, 03:04 PM   #7 (permalink)
XFordGuy's Avatar
C5's don't require any programming. I'm going to have to read up on how the C6 works.
Old 12-07-2012, 03:47 PM   #8 (permalink)
itsaz's Avatar
I missed the thread. What happened?
itsaz is offline   Reply With Quote
Old 12-08-2012, 12:46 AM   #9 (permalink)
Hey Tom! I had my baby hooked up to a battery tender. Came home one day and the tender was blinking both green and red. It shouldn't be doing that. It should either be blinking red (showing charging) or a solid green (charged). I didn't think to much of it until I went to drive the car. I get up to 10 MPH and I get all the lights. Check ABS, Active Handling, Traction Control. It does this over and over. I check the system with a code reader and I get several codes. I can't remember them now but, basically, your EBCM brain is fried.
I removed the EBCM, sent it to a place that repairs them. They sent it back saying they don't repair EBCMs after 04 because of "hardware issues". Nice, why don't you say that in your ads!
Come to find out, EBCMs 05 and newer are designed so they can't be repaired or swapped between car without being programmed. Requires a Tech 2 and access to the GM data base (TIS 2).
Anyway, I no longer leave my car hooked to a battery tender during a storm, and only with a surge protector in line any other time.
EBCM should be very reliable as long as you ain't connected to the "grid"!
Old 12-08-2012, 02:59 AM   #10 (permalink)
itsaz's Avatar
Wow! Glad it's fixed. I wonder if your homeowners insurance would have paid for the EBCM. The deductible was probably higher than $975 though. Was any other electrical equipment damaged at the same time?
Old 12-08-2012, 09:11 AM   #11 (permalink)
My agent said it would be covered, unfortunately, my deductible is 1k.
Old 12-08-2012, 11:36 AM   #12 (permalink)
itsaz's Avatar
I figured as much, that's why I asked about other damages. Oh well, it's only money!
Finaly I have a Vette Cyberone Introduce yourself 8 09-22-2010 04:57 PM
Caravaggio spoiler finaly outside the garage! matt3310 C5 Z06 - Grandstand 7 08-07-2009 10:10 PM
finaly bought the ccw drag pack!!!! U LUZ C5 Z06 - Pit Road 8 02-23-2005 01:01 PM
ATI - PROCHARGER finaly making more boost MIKE-HKS C5 Z06 - Forced Induction & Nitrous 11 01-28-2004 03:54 PM
FIXED add some speed to ur day FIXED TheKid C5 Z06 - Grandstand 7 01-04-2003 06:02 AM
» Insurance
» Latest Auto News
Mercedes CLK Badge to be Revived in Next-Gen C-Class Coupe
When the next-generation Mercedes-Benz C-Class coupe surfaces in 2016,
Most Researched Cars of the Week: May 19 25
Imports exclusively held the top spots this week in
Watch Brembos Contribution to Fast and Furious 6 Video
Fast and Furious 6 is officially on the big screen, so chances are
» New Car Reviews
2013 Nissan Pathfinder vs 2013 Hyundai Santa Fe
Family faceoff: Comparing the two newest three-row crossovers
2014 Chevrolet Cruze Diesel Review
Chevy builds a surprising Jetta TDI rival
2013 BMW X3 xDrive28i Review
2014 Scion tC Review - Video
» Featured Product
