Old 03-26-2008, 01:20 PM   #1 (permalink)
pauln64's Avatar
fob?
I hadn't seen the 08 key fob's but from what I read it has the integrated key in the fob. If that is the case, can an 08 fob be programmed for my 06?
Old 03-29-2008, 06:51 PM   #2 (permalink)
Re: fob?
The integrated key - I think you are referring to - is to manually open
the rear hatch. You'd have to change out your lock in the hatch as
well as reprogram.
Is that what you are asking?
Hawkeye2 is offline   Reply With Quote
Old 03-29-2008, 07:40 PM   #3 (permalink)
pauln64's Avatar
Re: fob?
well as reprogram.
If I get a new fob, I know that is has to be reprogrammed. I was thinking that the key that will be in the fob can be cut to match the key now...unless it's a totally different key size.
Old 03-30-2008, 06:21 AM   #4 (permalink)
XxMFxX's Avatar
Re: fob?
sorry for the camera phone its the only one i have in my hand
hope it helps
XxMFxX
XxMFxX is offline   Reply With Quote
Old 03-30-2008, 01:43 PM   #5 (permalink)
Re: fob?
I get it. Maybe the photos will help you compare keys.
If I was closer I'd let you see mine!
Old 03-30-2008, 08:00 PM   #6 (permalink)
pauln64's Avatar
Re: fob?
looks like it might be different. I am going to the Chevy dealership tomorrow, I'll ask to see if it's possible w/o having to get a new lock.
Old 03-31-2008, 03:25 AM   #7 (permalink)
XxMFxX's Avatar
Re: fob?
you gotta put in your mind thou that the fob key comes into 2 pieces the plastic transmitter and the metal key with the silver base
ordering the transmitter is easy .. but the metal key has to be ordered with your cars code i think in other way if you car is older than an 08 maybe you will get an old one
not sure.. be sure to ask if you can get it .. and please keep us posted
Old 03-31-2008, 09:55 PM   #8 (permalink)
The 2006 used different locks. Sorry, but you can't do it without changing out the locks. But the fob will work no problem.
xxMFxx,
Sweet looking ride.
Old 03-31-2008, 10:08 PM   #9 (permalink)
pauln64's Avatar
Re: fob?
xxMFxx,
Sweet looking ride.
thanks for the info. That takes my idea out of the picture. I was looking at the 08 fobs b/c I like the integrated key.
Old 04-01-2008, 05:47 AM   #10 (permalink)
XxMFxX's Avatar
Re: fob?
xxMFxx,
Sweet looking ride.
thanx
Old 04-01-2008, 09:27 PM   #11 (permalink)
Originally Posted by XxMFxX View Post
thanx
No problem. Good to have Saudi Arabia representing on our site.
Alex
Old 04-02-2008, 04:41 AM   #12 (permalink)
XxMFxX's Avatar
Re: fob?
good to be here
Old 06-16-2008, 04:49 PM   #13 (permalink)
Re: fob?
Just inquired with the dealer about upgrading a fob on my '07. They had lost one at the dealership before I took delivery. If they can get the key cut, I will let everyone know!
bigmellon is offline   Reply With Quote
Old 06-16-2008, 10:06 PM   #14 (permalink)
The keys work on the '07 without a problem. That shouldn't be an issue.
The question in this thread is if they would work on the '06 - and they wouldn't because they used different locks that year.
Old 06-17-2008, 06:41 AM   #15 (permalink)
6speeder's Avatar
Re: fob?
I considered changing to the '08 integrated key/fob for my '07, but after looking at one changed my mind. The '08 fob is even bigger than mine and as it rarely leaves my pocket when I'm driving, will be even more of a pain.
Personally, I just don't see the "no key required" a a step up, just a gee whiz answer to a question no one asked or needed.
Porsches for breakfast
Ferraris for lunch
