Old 06-24-2008, 05:08 AM   #1 (permalink)
Getting service tomorrow -- CAGS, has anyone
had it turned off? You know, the 1-4 shift lock out/light thing. I don't like it one bit, but I trying to determine how best to shut it off. I don't want to risk messing up a fairly sophisticated system of computers in the 08 Z.
Zoeaux6 is offline   Reply With Quote
Old 06-24-2008, 05:53 AM   #2 (permalink)
6speeder's Avatar
Re: Getting service tomorrow -- CAGS, has anyone
You can eliminate it as part of a tune or there is a module available that you plug in the the electrical connector instead of the transmission. It fools the computer that it's still hooked up. It takes longer to get the car up in the air than it takes to connect.
2007 Velocity Yellow Z06
543 rwhp/493 rwtq SAE
Old 06-24-2008, 11:16 AM   #3 (permalink)
pauln64's Avatar
I'm using the same skip shift eliminator that I had on my 04 and works great w/o any type of electrical issues (knock on wood.)
Old 06-24-2008, 11:19 AM   #4 (permalink)
The skip-shift eliminator is a must-have. About $20 or $25, and easy to plug in--just raise the back end to get access to the wiring, take it apart at a connector, and add in the new gizmo. Try Corvettes of Houston.
Gersh
2006 Corvette Z06--DSOM
1968 Dodge Charger RT 440--Red
2007 Kawasaki ZZR 600--Black
I think, therefore I am
--Rene Descartes
I am, therefore I think
--Gersh Lundberg
Gersh is offline   Reply With Quote
Old 06-24-2008, 03:28 PM   #5 (permalink)
BEZ06's Avatar
As has been mentioned, you can get a skip-shift eliminator to plug into the solenoid. You an also buy a 5 cent resistor from Radio Shack and wire it into the solenoid connector, but I don't know what resistance you need. Getting the weatherproof unit is probably a good idea.
Or, if you get a tune, you can tune it out with any of the tuning software programs.
If you put an eliminator unit on the solenoid connector you'll still get the 1-->4 shift light, but you'll be able to go right into 2nd with no problem.
With a tune, you won't get the light anymore.
Bob
BEZ06 is offline   Reply With Quote
Old 06-24-2008, 08:15 PM   #6 (permalink)
One of the things you want to do right away. You'll wonder why you didn't do it earlier.
Old 06-25-2008, 02:10 PM   #7 (permalink)
1.6k resistor 1/4 watt
k4site is offline   Reply With Quote
service tcs service abs service active handling roadrash9r The Garage 3 05-10-2005 03:51 PM
Service ABS / Service Traction Control light came on ! ElectronZ06 C5 Z06 - Pit Road 13 09-17-2003 04:25 PM
Service Vehicle Soon/Service Active Handling ROSSO Z C5 Z06 - Pit Road 12 08-16-2003 05:34 AM
CAGS defeat - more than just CAGS? dimer0 C5 Z06 - Pit Road 8 07-01-2001 05:42 AM
Service Active Handling/Service Vehicle Soon N4C5S C5 Z06 - Pit Road 3 03-27-2001 02:59 AM
