Old 06-13-2008, 05:57 AM   #1 (permalink)
jrhunkler's Avatar
Hotchkis Sway Bar Kit: Opinions needed please!
I want to make my suspension even better than it is. I know this sounds crazy, but I have the mod bug, and I need to get rid of it!
If anyone has these, or a different recommendation, please let me know the actual benefit of these? Also considering Pfadt coil-over kit... Will I even feel a difference if I don't track the car?
Thanks in advance.
jrhunkler is offline   Reply With Quote
Old 06-13-2008, 08:28 PM   #2 (permalink)
In the case of the C5 Z, the Hotchkis sway bar is *not* better than the Z06 sway bar - I think it may be the same scenario with the C6 Z. If you want handling, I would recommend a coil-over kit and stickier tires.
Old 06-13-2008, 10:07 PM   #3 (permalink)
Re: Hotchkis Sway Bar Kit: Opinions needed please!
The first and best 'mod' is always seat time, on a track. During which time you'll spend a fair amount of money on brake pads, rotors, tires and fluids, stock or otherwise.
The next step would be additional brake cooling (cooling ducts), perhaps a larger radiator, lower temp thermostat and a tune that optimizes coolant temps.
After that, if you haven't already, aftermarket wheels sized for race rubber. By this time you may start thinking about a car trailer and a means of towing it.
At some point safety items need to be considered. This includes a seat, harness, HANS device or similar and perhaps roll protection. I am not a fan of harness bars, however.
After you've done all of that you may want to consider suspension modifications. But be aware, engineering a suspension is not as simple as bolting on some parts and calling it good.
The bottom line is, if you have the money there are many ways of spending it without suspension mods.
Old 06-16-2008, 05:34 AM   #4 (permalink)
jrhunkler's Avatar
Thanks... what will the coil over kit do for me in every day driving? Feel smoother? or just take turns better?
Hotchkis Sway Bar Question Cash C5 Z06 - Pit Road 2 07-17-2006 03:17 PM
wtb Hotchkis sway bar zohhhsix Member Sales - Parts & Cars 3 02-17-2005 12:22 PM
WTB: Hotchkis Sway Bars tjdz06 Member Sales - Parts & Cars 3 01-11-2005 09:33 AM
Hotchkis Sway Bars G Stamatakos C5 Z06 - Pit Road 5 07-20-2002 01:44 PM
T-1 vs Hotchkis sway bars Chicago ZO6 C5 Z06 - Pit Road 23 07-16-2002 11:07 AM
