Old 10-29-2006, 07:01 PM   #1 (permalink)
Lifting the 2006 Z06
Ok, I've searched everywhere and I just can't come to a proper discription on how to rasie my Z off the ground. She's about to go to bed for the winter season and I want to remove the wheels and keep her on blocks. Can anyone give me some advice. I've read many articles, but have not found any on the 2006 C6 Z06.
Thank you in advance
Do you DOO?
getvette is offline   Reply With Quote
Old 10-30-2006, 06:32 AM   #2 (permalink)
MSiska's Avatar
I use a 1.5 ton jack under the rear suspension cradle to lift the entire rear. The front I have used Rhino ramps to get the front end up enough to get my jack under the front suspension cradle. Or you could buy one of those low race jacks to gwet under the front.
Old 10-30-2006, 07:12 AM   #3 (permalink)
It's funny that you should mention this - I just built my ramps yesterday. For each wheel, I used (2) 2x12's stacked and cut with a 45* front edge for easier wheel entry. Also, I have a strip of carpet attached to the bottom of the ramps to prevent slippage. Four Rhino Ramps cost about $80; my ramps cost $25 total.
As for the actual jacking procedure, I don't know if it differs from the C5. If not, there's a good thread on this for the C5 that you can also use for your C6. It's what I used as a reference.
http://www.z06vette.com/diy_lift.php
Lifting for Oil Change
"I put a dollar in one of those change machines. Nothing changed." ~George Carlin
4 good Toyo T1Rs - back in business / CAGS Defeat / Tint / Soon to be Lowered / DEAD Braille, now --> Walmart Battery / Seat Bolster Mod / HPDE Checklist
Old 10-30-2006, 08:05 AM   #4 (permalink)
Thanx for the responses. I think the C5 method is different tfrom that of the C6. I'll build the ramps and give myself a little more clearence to check the under side of the car. If anyone has any info on the C6, please chime in.
Thanx guys
Old 10-30-2006, 11:15 AM   #5 (permalink)
Send a message via AIM to DomsZ06 Send a message via MSN to DomsZ06 Send a message via Yahoo to DomsZ06
if you go look at the FAQ on the other vette forum it tells you what to do.
Dom
My baby Z was the 12th Z06 to roll off the line on July 10, 2006. It was the 148th Z06 to roll off the production line for 2007 and I picked her up on August 2nd!!
DomsZ06 is offline   Reply With Quote
Old 10-30-2006, 11:47 AM   #6 (permalink)
Thanx guys
I think the only difference between lifting the C5 and C6 using the method above is that the C6 doesn't have the same air dam underneath. The chassis is virtually identical.
Good luck,
Alex
Old 10-31-2006, 06:19 AM   #7 (permalink)
Guess you swapped out to ceramics?
My car is blue. My other car is red.
Z06Dad is offline   Reply With Quote
Old 10-31-2006, 06:39 AM   #8 (permalink)
MSiska's Avatar
Tomorrow Robert! Then...no more dust on my milky polished wheels!!
Old 11-01-2006, 04:51 AM   #9 (permalink)
Am I understanding?
Ceramic Brake pads?? No MORE DUST? Where do I apply?????
Old 11-01-2006, 04:52 AM   #10 (permalink)
Other? Is there another?
Dom
Thank you
Old 11-01-2006, 05:29 AM   #11 (permalink)
Not "no more", just a lot less. Mine is a daily driver now and I still see the build up.
Would I put them in again? Definitely...
'02 EB Z06 Museum delivery 9/13/01
Lloyds Z06 mats, Borla Quad Stingers, Power antenna, Sill protectors,A&A Frame Savers, Ceramic pads, CLB, V1, Tinted Windows, Partition, 3rd brake light flasher, hood seal, trunk liner, Cover for the hole in the trunk that everything falls into.
02EBZ06 is offline   Reply With Quote
Old 11-01-2006, 07:51 AM   #12 (permalink)
MSiska's Avatar
Thanks! Driving a Hummer H3 rental while my baby is in the shop for the rear end growl (2nd time-no clutch packs yet) and my worn drivers side left bolster.
And having them swap out to the ceramics!
Old 11-01-2006, 08:24 AM   #13 (permalink)
scotts's Avatar
For what its worth, on my C5, I built some blocks out of 2x6's
Threw the jacking pucks in the slots, raised the car (front first was easier) and put the blocks under the jacking pucks and dropped it back down. Then did the same with the back.
I ended up just having the car setting on 4 blocks.
I would assume the C6 has the same spots for jacking pucks.
scotts is offline   Reply With Quote
Old 11-01-2006, 12:39 PM   #14 (permalink)
I think that should work.
Old 11-02-2006, 07:31 AM   #15 (permalink)
Her's my question. If you are jacking how can you remove the jack to put the blocks under? It has a location to jack which is about the size of a puck. The rest of the botom (underder the rocker panel) is covered in beautiful red finish - I would not want to scratch that.
Lifting pucks, whose got em' Joslyn Vendor Sales - C5 7 03-09-2003 08:11 PM
Lifting a tire? What does it take? McRat Racing 9 01-18-2003 04:13 PM
Lifting the rear of my Z 06n C5 Z06 - Pit Road 4 03-12-2002 06:57 AM
Lifting car - is this ok? dimer0 C5 Z06 - Pit Road 10 07-02-2001 10:35 AM
Lifting the Z06 ELF Z06 C5 Z06 - Pit Road 1 03-19-2001 09:17 AM
