Old 04-12-2004, 07:22 PM   #1 (permalink)
LS2 Info
From "For Vettes Only" Improvements over the LS1
6.0 Liter, higher lift cam, flat top pistons w/ floating wrist pins, cast baffling oil pan, 33% lighter exhaust manifold, more efficient coil banks, 10.9:1 compression, 90 mm TB, reduced mass & better water pump, 6500 rev limiter, heads similiar to Z06, 2 in intake & 1.55 in exhaust valves with upgraded springs, stronger timing chain, iridium tipped spark plugs, aluminum block with cast-in-place iron cylinder bore liners, aluminum valley cover & upper deck rails, 2 horizontal cross bolts & 4 bolt mains, better cats, better engine controller
Austin01QS is offline   Reply With Quote
Old 04-12-2004, 07:29 PM   #2 (permalink)
All that baby needs is a Headers and a Cam and it will be a monster
Old 04-12-2004, 08:33 PM   #3 (permalink)
LS2 < LS7. Nuff said.
Wb: Ls2 SuperSportTruck Vendor Sales - C6 0 01-02-2006 11:39 AM
How about an LS2 with AWD. Cave Man The Garage 13 04-22-2005 02:28 PM
BO-RFA info inside! my problem fixed. info for others CYEAL8R C5 Z06 - Pit Road 4 05-23-2004 06:49 AM
C6 Engine Info-LS2 & LS7. Zippy The Garage 24 08-18-2003 03:20 PM
Info I read on the other forum! Just info. guys! ANDY Vendor Sales - C5 1 09-22-2002 09:39 PM
