Old 06-09-2004, 11:33 AM   #1 (permalink)
LS2 vs. LS6 Dyno Graph
Has this been posted before? Is it for real? How can the LS2 have such a 'fat' torque curve compared w/LS6?? This would imply the C6 is going to crush the C5 Z06.
Dreamin is offline   Reply With Quote
Old 06-09-2004, 11:46 AM   #2 (permalink)
Also, keep in the mind the weight difference between a standard C6 and a Z06. I am not sure how much it is, but I still beleive the Z is lighter.
NinjaZ06 is offline   Reply With Quote
Old 06-09-2004, 11:58 AM   #3 (permalink)
Send a message via AIM to NETfiend
From what I understood, the LS2 isn't going to have the triple valve technology. That is some soul crushing torque from the LS2 compared to the LS6 though.
Sand fleas are eating the internet cables!!!
NETfiend is offline   Reply With Quote
Old 06-09-2004, 12:21 PM   #4 (permalink)
PerforminNorman's Avatar
Wow, that's exciting. More displacement, more valves, more torque? How does the bore and stroke compare? Usually more stroke = more torque.
Come to the Z06 Fest!
Performin' Norman
Old 06-09-2004, 12:23 PM   #5 (permalink)
Send a message via AIM to benenati379 Send a message via MSN to benenati379 Send a message via Yahoo to benenati379
The LS2 head is a 16 valve / 2 valve per cyl configuration.
Thanks for the post. That is exactly what I was waiting for! I have posted before that I was more excited about the torque curve the LS2 would make, then the peak hp/tq numbers. That new torque curve is sure going to make the new C6 easier to drive fast and feel more powerful when its just cruising around. It probably wont have to work it as hard as the LS6 to go as fast.
Wow, it really looks like it make a LOT more torque under the curve.
Vince
benenati379 is offline   Reply With Quote
Old 06-09-2004, 12:23 PM   #6 (permalink)
Send a message via AIM to sil350
yes this was posted earlier by me. that torque down low is gonna be awesome
sil350 is offline   Reply With Quote
Old 06-09-2004, 12:25 PM   #7 (permalink)
I believe that the LS2's displacement increase is all bore. Just a bump to an even 4.0 inch bore and same stroke.
Old 06-09-2004, 12:27 PM   #8 (permalink)
Thanks for the info.
Old 06-09-2004, 12:30 PM   #9 (permalink)
Wingnut's Avatar
Thanks for the info. It makes me appreciate the torque curve with my Magnacharger even more.
Magnacharger/Longtubes/RandomTech HiFlow Cats/Vortex Rammer/
MGW Knob/Borla 2-Tip Stingers/ShanerS2 TB/OEM Z06 Wheels painted black/polished lips/ACI Hood/Exedy Hyper Single Clutch/Blower Cam/495rwhp/481rwtq/3:90's with hardened output shaft
Wingnut is offline   Reply With Quote
Old 06-09-2004, 01:54 PM   #10 (permalink)
50 extra cubes-no substitute for displacement.
02 Z06 CDN PERF 347 F1C, RPM 4L65E conversion
BEST ET 9.6
BEST MPH 146
vortech is offline   Reply With Quote
Old 06-09-2004, 02:04 PM   #11 (permalink)
It is more like half that. Like around 20 cubic inches. The LS2 is 364.9ci / 5970cc.
Bore is 4.0 and stroke is 3.62
But I agree, there is no substitue for displacement.
Old 06-09-2004, 02:08 PM   #12 (permalink)
for some great pics as well as more technical pics of the c6 look here Great pics from C5/C6 B-Day Bash
Old 06-09-2004, 02:16 PM   #13 (permalink)
I thought the LS6 made 400 lb-ft of torque not 390? The HP numbers look accurate.
Phaster is offline   Reply With Quote
Old 06-09-2004, 09:09 PM   #14 (permalink)
hp is calculated from torque.........how can the torque curves be so different yet the hp curves are similar? Answer is.......it can't, something's fishy. Now before anybody starts assaulting me, be sure and bring some math, because I've used superflow engine dyno's for the last 9 years. I've already proved that two aftermarket manufacturers were claiming faulty numbers simply because the two didn't add up in their published advertisements. People in buisiness expecting to take your money will actually show you a dyno graph where the hp number doesn't equal torque in ft./lbs x RPM / 5252. I guess buyer beware.
truckrookie is offline   Reply With Quote
Old 06-09-2004, 09:38 PM   #15 (permalink)
I just did the math and their graph is correct.
Example:
390 ft.-lbs. @ 4000 RPM
297 h.p. @ 4000 RPM
As closely as I can tell by looking at that graph.
Since H.P. = Torque X RPM/5252
Then:
390 ft.-lbs. X 4000 RPM = 1560000
Then:
1560000/5252 = 297 h.p. @ 4000 RPM
FS: ls6 block, ls6 243 heads, ls2 gto crank pulley dvandentop Member Sales - Parts & Cars 5 11-11-2006 03:38 AM
Stock LS6 vs. LS2 dyno comparison??? dsinned C5 Z06 - Pit Road 2 05-03-2005 01:14 AM
A4 C6 header's dyno graph Davidjbusch C6 Z06 - Grandstand 4 11-21-2004 07:29 AM
Dyno graph Don Benson C5 Z06 - Pit Road 27 04-08-2004 12:32 PM
h/c dyno graph before and after Ianz06 C5 Z06 - Pit Road 0 05-27-2003 10:22 AM
