Old 07-17-2006, 04:25 PM   #1 (permalink)
Running non-Run flats
The car sits very low with the stock suspension. What would happen if you have racing tires that are not run flats and you get a blow out at high speed? Will the car bottom out at the respect tire? Let's say the right front goes. Will it scrape the front fascia? If the rear blows, will it drag the exhaust?
I'm just wondering if runflats are needed in that event...
Ralf Racing, Inc. www.ralfracing.com
Fighting for the Cure - Leukemia and Lymphoma Society Partner
Car #25 Spec Miata SCCA - Racing in the Mid Atlantic Road Race Serries (MARRS) 2008
2006 Z06 Corvette for more fun...
Blitz is offline   Reply With Quote
Old 07-17-2006, 04:28 PM   #2 (permalink)
PerforminNorman's Avatar
Eye ball the lowest part of the rim. Is it lower than the side skirts? If so, yes. It will scrape. If not, then you are fine. I'm too lazy to go up and look at mine. Sorry. haha
Based on this pic I took after lowering mine on stock bushings and bolts, I'd say no problem. I, too am going non runflats when I need new tires.
Come to the Z06 Fest!
Performin' Norman
Old 07-20-2006, 12:26 PM   #3 (permalink)
WhosUrDaddy's Avatar
What other options are there on stock rims?
LB/BLK '06 Z06
WhosUrDaddy is offline   Reply With Quote
Old 07-20-2006, 02:34 PM   #4 (permalink)
Nice car, Norm.
How about some RIIs for the fronts and Hoosiers for the back?
I would also ditch the run-craps.
Alex
Run Flats GlennSullivan C6 Z06 - Pit Road 11 10-24-2005 06:22 PM
C6 Zo6 to have run-flats? bigvette C6 Z06 - Pit Road 1 03-19-2005 01:20 PM
Run Flats Stock?? stevep1794 C5 Z06 - Pit Road 3 01-24-2005 11:16 AM
11's on Run flats Homeslice (tm) Racing 3 08-03-2004 09:53 AM
F/S Goodyear Run Flats LC Member Sales - Parts & Cars 0 07-22-2003 11:34 AM
