Check and see if you have a B0516 code, which is a Speedometer signal circuit malfunction.
1. Turn the ignition key to the ON position, but do not start the car.
2. Clear any pre-set messages by pressing the RESET button.
3. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a code that was registered previously but is no longer an issue.
4. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
5. To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES".
6. Press OPTIONS button to go to the next module.
Repeat these steps until you have reset the codes in all of the modules. Note: It is not necessary to reset the codes unless you want to.
