Old 04-23-2008, 09:36 PM   #1 (permalink)
start button noise
OK, this is not a big issue, but why does my start buttom make a few quick clicks before starting or stopping my 08Z? What is it doing? Morse code to the starter motor??
Old 04-23-2008, 09:51 PM   #2 (permalink)
jkgt's Avatar
Re: start button noise
I second that question?
I drive fast so you dont have too!!
unless your following me!!!!
jkgt is offline   Reply With Quote
Old 04-24-2008, 12:55 PM   #3 (permalink)
Pressing the Start switch sends a discrete input to the body control module (BCM) notifying it that engine start has been requested. The BCM then verifies that the key fob, with the correct code, is in the vehicle.
After this information has been verified the BCM grounds the control side of the RUN/CRANK relay closing the switch side of it and allowing battery positive voltage to flow from the BATT 3 fuse through the RUN/CRANK Relay switch, engine control module (ECM) Fuse to the battery positive voltage side of the Crank relay coil. The BCM also sends a high speed GMLAN message to the ECM requesting engine start.
The ECM will then verify that the internal mode switch (IMS) is in Park, Neutral, or clutch depressed. After this has been verified the ECM grounds the control circuit of the CRANK Relay closing the CRANK Relay Switch Circuit and allowing battery positive voltage to flow through the STARTER Fuse, the CRANK Relay switch to the S-terminal of the starter solenoid cranking the engine. Ground is supplied through the engine block.
ZZMike is offline   Reply With Quote
Old 04-25-2008, 06:20 PM   #4 (permalink)
oh, yeah I was thinking that, but wasn't sure
wow, I'm impressed. thanks for the info.
Old 04-25-2008, 06:33 PM   #5 (permalink)
What your hearing is a series of relays that the demand your asking for, start or shut down etc. I still miss my C5 key.
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 05-05-2008, 01:07 PM   #6 (permalink)
XxMFxX's Avatar
i agree but dosent the clicks sound like where in the 70`s ?
i used to have an 2007 M5 and no clicking when i press start
to be honest the clicking sounds feels that the relays are CHEEEEP and givs me the feeling its going to catch fire
XxMFxX
XxMFxX is offline   Reply With Quote
Old 05-05-2008, 02:07 PM   #7 (permalink)
Originally Posted by XxMFxX View Post
i agree but doesn't the clicks sound like where in the 70`s ?
to be honest the clicking sounds feels that the relays are CHEEEEP and gives me the feeling its going to catch fire
Question for you?
Are you holding the button in? If so try just touching it once to start the car. It's not necessary to hold the button in.
Old 05-05-2008, 02:15 PM   #8 (permalink)
XxMFxX's Avatar
Originally Posted by IT L GO View Post
Question for you?
ok heres what i do to start it foot on clutch all the way and touch** the start key then i hear click click click VROOOOM (ON)
to switch off press and hold the (0-acc) botton then i hear click click click boooosh (OFF)
**touching is not holding it in
Old 05-05-2008, 08:49 PM   #9 (permalink)
I'll try the touching thing...I know the difference between touching and holding it in
I was told by the NCM guy to hold the button in until it starts or stops, sos I did...
Old 05-05-2008, 09:30 PM   #10 (permalink)
You need to send an Email to the NCM Guy and tell him to read the owners manual page 2-24
From the 2008 owners manual
2. When the engine begins cranking, let go of the
button and the engine cranks automatically until
it starts. If the battery in the Key-less access
transmitter is weak, the DIC displays FOB
BATTERY LOW. You can still drive the vehicle.
See “Battery Replacement” under Key-less Access
System Operation on page 2-5 for more information.
If the fob battery is dead, you need to insert the
fob into the fob slot to enable engine starting. See
“No Fobs Detected” under DIC Warnings and
Messages on page 3-55.
Old 05-10-2008, 06:59 AM   #11 (permalink)
I think he was saying "until it starts to crank" which is exactly what I do and the manual says...I tried your way and it works too. Makes no difference in the relay noise as expected. thanks.
Alarm System/ Push Button Start Wes1927 C6 Z06 - Grandstand 0 06-27-2006 11:57 PM
Push button Start C5 1brich C5 Z06 - Pit Road 15 03-17-2006 12:03 PM
Push button Start in C5 ds760 C5 Z06 - Pit Road 12 09-12-2005 11:15 AM
heavy brake pedal modulation and noise on engine start up jacvily C5 Z06 - Pit Road 0 10-15-2004 08:42 AM
Start button Inferno C5 Z06 - Grandstand 13 12-11-2002 11:21 AM
