"Synchro Shift II from BG Products"
Anyone ever use this stuff? A friend of mine just started working for them, and swears it will smoothen things up quite a bit... gave me some for free... just curious if anyone ever used it...
says it's good for:
transmissions, transaxles, and transfer cases... ???
From the website:
BG Syncro Shift® II BG Syncro Shift® II is a gear lubricant specially formulated for front wheel drive (does it matter?) manual transmissions. It does not sacrifice any performance as does engine oil, ATF or conventional gear oil. It provides required thermal stability, low-temperature fluidity, hot rattle suppression, noise dampening at operating temperature, outstanding extreme pressure characteristics, shear stability, smoother shifting characteristics, wear reduction (synchronizer, gears, bearings, shift fork), seal compatibility, and reduced maintenance costs.
