Old 06-12-2008, 05:34 PM   #1 (permalink)
jrhunkler's Avatar
"Synchro Shift II from BG Products"
Anyone ever use this stuff? A friend of mine just started working for them, and swears it will smoothen things up quite a bit... gave me some for free... just curious if anyone ever used it...
says it's good for:
transmissions, transaxles, and transfer cases... ???
From the website:
BG Syncro Shift® II BG Syncro Shift® II is a gear lubricant specially formulated for front wheel drive (does it matter?) manual transmissions. It does not sacrifice any performance as does engine oil, ATF or conventional gear oil. It provides required thermal stability, low-temperature fluidity, hot rattle suppression, noise dampening at operating temperature, outstanding extreme pressure characteristics, shear stability, smoother shifting characteristics, wear reduction (synchronizer, gears, bearings, shift fork), seal compatibility, and reduced maintenance costs.
jrhunkler is offline   Reply With Quote
Old 06-16-2008, 06:37 AM   #2 (permalink)
jrhunkler's Avatar
Re: "Synchro Shift II from BG Products"
*bump*
Old 08-09-2008, 01:58 PM   #3 (permalink)
I replaced the fluid in my 2002 Z06 with Synchro Shift and noticed a substancial improvement in shift performance. I was using Royal Purple synthetic prior to switching. Good luck.
Phastang is offline   Reply With Quote
Old 08-09-2008, 11:49 PM   #4 (permalink)
jrhunkler's Avatar
What kind of improvement? Smoother? I was thinking of going with a short throw, and then switching my fluid to this to keep some smoothness, but have it tight and fast.... make sense'?
Old 08-15-2008, 11:46 AM   #5 (permalink)
It feels easier to go in gear. I have a B&M short throw in my car and it just seems like its easier to slide into gears. From my past history, BG makes some wonderful products. 44K is hands down the best fuel system cleaner available. What short throw are you looking at?
Old 08-15-2008, 11:28 PM   #6 (permalink)
jrhunkler's Avatar
Looking at the BPP from Breathless Performance...
Part # for shift knob "T" lock? WA 2 FST C5 Z06 - Pit Road 4 08-20-2004 09:17 AM
MGW "T" Shift Knob NavyPhrog C5 Z06 - Grandstand 6 03-24-2003 11:27 AM
"Z06VETTE.COM Cabin Fever" Hardbar Shift Knob Give-Away! FUBU69 C5 Z06 - Grandstand 101 03-06-2003 10:15 AM
new "voodoo" shift knob wito03 Vendor Sales - C5 1 04-18-2002 01:43 PM
"Shift" Indicator in the HUD ZeeOhSix C5 Z06 - Pit Road 6 10-12-2001 06:22 PM
