Originally Posted by wm norris
my second 2006 z06 with the clutch chatter, my first one was a little noisy but this one i just bought about a month ago is bad,sounds like a ups truck in first and second. local dealer says inherant with the z06,but i called gm to see if i could get some sort of help for this issue anyone had any luck doing so ?? thanks
Did you buy used?
Some 2006 Z's had a flywheel problem from the factory that caused clutch chatter.
Not sure that's your problem, but it could be.
Should be covered under warranty if it hasn't been abused.
Let us know what you find out.
augydog
